Author Topic: NG Looking for a little HVAC info 86 C10  (Read 35410 times)
Offline 1970pelle
Re: NG Looking for a little HVAC info 86 C10
« Reply #15 on: November 26, 2007, 11:12:59 pm »
Okay.I apologize gentlemen.But I read your replys and it seamed that you didn't read my post.Because I thought I gave a clear discription of my problem/condition.And I kept getting vacuum supply problem/issues replys.So I posted pictures.The doors have to be time/adjusted correctly or they will hit/bind.Its not a common issue.Becuase there is no real need to disconnect the rod for HVAC box service.But in my case it got disconnected.I have found the correct procedure on Alldata.No need to respond.Matter closed.On to bigger,better projects.
« Reply #16 on: November 27, 2007, 12:47:19 pm »
If you found it in and it differs from what is posted here vs alldata then why not post it here for others?
