Author Topic: fiberglass cowl induction hood  (Read 15332 times)
Offline 80stepsideguy
Re: fiberglass cowl induction hood
« Reply #15 on: February 25, 2008, 01:59:21 am »
I agree w/ blazin,
the 81-7 had a bolt on cowl cover and had to extend the wiper arm studs so the could have clearance.What you mey need to do is go to a junkyard and  look for a complete wiper arm assembly unit from a 1973-1980 style truck that has the shorter stubbies and bolt it in.But look at the cowl i think the 81-7 drivers side wiper arm assembly was 3 bolts and the 1973-1980 are 2 bolts that hold it into place if you got a 3 bolt setup you got the newer setup. You`ll just have to either weld up the holes and drill new ones for the wiper arm assembly, and you may have to do the same for the pass side arm assembly as well.
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #16 on: February 25, 2008, 06:27:53 am »
I have swaped them from one to another before. I didn't weld up the holes, just hogged them out. they are not off by much. A small OD washer takes care of it.
Offline plowking_90
« Reply #17 on: February 25, 2008, 06:31:36 am »
itsa not the wiper transmision it the hood it self, the wiper tansmision is the same as my 77 im just gonna trim the hood a little not like it a show truck or anything thanks for the help
« Reply #18 on: February 25, 2008, 06:41:12 am »
Cool. sorry for the huge discusion then.
