Author Topic: 2 or 4  (Read 17370 times)
Re: 2 or 4
« Reply #15 on: March 07, 2008, 08:38:41 pm »
[/quote]
totally outrageous m8! a litre petrol is £1.12 so I guess thats about $2.30
I'm just very thankful I have a diesel car for everyday use that gets about 55mpg ;)
I  just paid $3.09 for gas and saw $3.93 deisel here in West Texas...Trade ya    I have a buddy running over 600 hp with nitrous on a 2 bolt with the splayed caps. He had a 4 bolt but is shelled out at the track with a little less power
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #16 on: March 08, 2008, 04:37:09 am »
Is this for the crewcab?
yup its for the crew-cab = where do I look for numbers! :)
 Restoration a little slow due to work, weather and space. I'm so envious of you guys over there with huge double garages etc. I have 3foot at the front and 2foot either side to work in!
I  just paid $3.09 for gas and saw $3.93 deisel here in West Texas...Trade ya - You sure? thats a litre not a gallon :o
1979 GMC CrewCab  C20 1t
Re: 2 or 4
« Reply #17 on: March 08, 2008, 08:06:57 am »
I see the error of my ways.....I was thinking gallons not liters.  My wallet aches just thinking about it.
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #18 on: March 08, 2008, 03:25:13 pm »
If it is a Quadrajet it will have numbers stamped on it.
If it is a Quad, you should be fine swapping it.
had a quick look earlier- under the edlebrock air filter I have..........a holley!
Re: 2 or 4
« Reply #19 on: March 08, 2008, 09:32:48 pm »
Still will have numbers stamped on it, generally on the body.
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #20 on: March 11, 2008, 05:29:57 pm »
Okay guys - had a nose but cant see any numbers    :(   or maybe I'm looking in the wrong place!  HELP
Re: 2 or 4
« Reply #21 on: March 11, 2008, 05:34:23 pm »
Look on the side of the carb behind the bowls.
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #22 on: March 11, 2008, 05:37:19 pm »
could you give me an idea of what the numbers should look like or just a part number?
cheers for mega quick reply!
Re: 2 or 4
« Reply #23 on: March 11, 2008, 06:00:03 pm »
It will be about 8 numbers long.  It might be on the choke horn also.
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #24 on: March 11, 2008, 06:04:39 pm »
Thanks Capt, I'll look tomorrow as its now 11pm here!
Offline red4wd
Re: 2 or 4
« Reply #25 on: March 11, 2008, 06:06:24 pm »
It should look something like this...
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #26 on: March 11, 2008, 06:08:24 pm »
Diamond Red  ;)  cheers
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #27 on: March 13, 2008, 05:07:22 pm »
okay guys- question time! the numbers off the carb =  3310-6      D120  can you identify what Holley it is?
And the next question. I assume this is something to do with cruise control? Can I isolate it and put the speedo cable into the back of the speedo? Or is it needed!!
Offline Bitzer!
  • Smiles per gallon
Re: 2 or 4
« Reply #28 on: March 13, 2008, 05:10:17 pm »
oooops it has a serial number of = 315728
cheers
Offline red4wd
Re: 2 or 4
« Reply #29 on: March 13, 2008, 05:47:38 pm »
Bitzer...that is a 750 cfm carb with vaccum secondaries.
