Author Topic: My very ugly 83 K20  (Read 27861 times)
Re: My very ugly 83 K20
« Reply #15 on: March 26, 2008, 06:30:53 am »
I was saying IF I take it to bare metal I use several methods. Which one I use depends on the type of job, and or the panel I am working on. Kind of a judgment cal if you know what I mean. In your case if I would leave the white on if
(1) It is in good shape.
(2) If your building a driver, not a show truck.
Also the area of the country you are from I am willing to bet the sheet metal is probably in great shape rust wise.
As far as a DA yes Dual Action. Meaning the pad moves in two different directions. I do use 36 grit on a 6" DA once in a while but usually the coarsest grit I use on my 6' DA is 80 grit. I use 36 grit on my big grinder on an 8" pad to strip paint. Also on my mud eater with an 8" pad for cutting body filler down. Mud eater is almost the same as a DA but is an 8" pad, turns allot slower RPMs, and the circular motions are bigger in diameter. Wal Mart doesn't sell Air Craft Stripper around here. The only places I know to get it is an auto parts store with a paint counter.
POR 15 is a great product but double the price of Chassis Saver, and they are the same thing.
( POR stands for Paint Over Rust. )
It says on the cans you can go over tightly adhered rust, or sand blasted metal. I have gone over rust hundreds of times and never had it come through. Yes you can top coat them but it has to be done before they cure, or you have to use their special etching primers to get a top coat to stick. Not topcoating them will be OK if they are not exposed to UV light, ( the sun ). On the other hand I am a sucker for if a little is good allot has to be better!! As far as spraying it you don't need to that stuff flows out so nice. When you spray it you need to have a complete body coverage, face shield etc. as it does not come off your skin once its been there for a bit. Spraying it blows back on you. Trust me I learned this the hard way. Had a lightly black speckled face for about a month!
 Do a search of old posts here I, and a few others have written tons of stuff on these types of things, along with body work etc. Also go to a book store (Barnes & Nobles or similar ) Get a few books on body work basics etc. Also I am not one to brag about the car and truck magazines articles on body work most times because some of the stuff they publish is real but can get you in trouble if your not carefull. But Peterson's 4 wheel and off road, & Hot Rod both have good write ups on body, & paint work this month.
 The transfer case is a 208. I might be wrong but I don't think there is such an animal as a 206.
 Tearing right into it though looks like good progress.
Harold.
« Last Edit: March 26, 2008, 06:35:50 am by Blazin »
Offline KSU Wildcat
« Reply #16 on: March 26, 2008, 08:59:24 pm »
Since I am in the question asking mood, I got another one for you guys.  What Type of spray guns do you guys recommend and now much will I be looking at spending?  I don't need the top of the line b/c i am not a professonal but I am a firm believer in you get what you pay for.  I only want to buy it once.  I have a 33 gal air compressor to run it.  I need to to spray the chssis saver, primer and of course the paint and clear.  Thanks guys.
83 K20 pos
« Reply #17 on: March 27, 2008, 03:21:40 am »
33 gallon compressor is in my opinion to small. Will work for the frame, and primer as long as you are not priming the whole truck at once. be OK for cutting in jambs etc, but not for an overall paint job. A buddy of mine has a 50 gallon 5.0 HP If I remember correct. I did a quickie paint job on his Toyota and it couldn't keep up.
 As far as spray guns I have several different brands. I bought a couple MAC Tools HVLP gravity feeds a few months back. They work real nice. Price wasn't bad either. around $250. Most not all inexpensive guns work fine for primers and such. they key is to keep them clean. Siphon fed guns are more forgiving in the clean dept.
« Last Edit: March 27, 2008, 08:06:53 am by Blazin »
Offline 80stepsideguy
« Reply #18 on: March 27, 2008, 04:12:30 am »
If i could go back in time i get a dual stage compressor.I got a 5 hp 60 gallon devilbiss compressor.As you mentioned blazin your right they cant keep up and get very hot fast.I had to put a window fan behind the motor to try n keep it cool but it dint work.I painted many cars in my garage and the best guns i have used were devilbiss FINISH LINE.I used cup guns for priming and the gavity fed guns for painting and clears.
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #19 on: May 11, 2008, 11:12:29 pm »
KSU,
any progress on your truck?Havent seen much since you ripped it all apart.
thanks
pat
