Author Topic: if you know anything about q-jets...look  (Read 11136 times)
Offline gold84gmc
Re: if you know anything about q-jets...look
« Reply #15 on: April 15, 2008, 09:03:56 pm »
thats a nice q-jet....mine doesnt look that good...that link helped...i found a couple things on there that might be causing the problem...thanxs for your help
92 buick century custom 3.3L
Offline Blue 82
« Reply #16 on: April 15, 2008, 09:31:02 pm »
What did you mean the air cleaner hits the float?  ???
That should have been air cleaner stud ( I deleated the post after I realized it would lead to flooding of the carb, like I experianced years ago when a friend installed the air cleaner stud in the slot in front of the air cleaner stud hole....yes a 1/4-20 stud will fit and push the float down).
The power piston usually isn't an issue unless you have really wild cam and aren't producing a ton of vacuum which you can also compensate for with a lighter spring.
JET and SMI use the screw to to adjust the part throttle mixture.
