Author Topic: Pictures of 1981  (Read 21912 times)
Offline 1983stepside
Re: Pictures of 1981
« Reply #15 on: January 09, 2009, 11:27:11 am »
hi i realy like your truck i was wondering if you know your bran of trans you have? im looking for a top mount transmission for my 83 2wd c10 stepper with a 350, but soon a 383 stroker, i want to keep it a manual but with out the linkage saginaw 3 speed i have , and that was bolted up to the 250 6 cylneder dont mean to change subject i was just wondering thanks
Offline cracker0169
    • Myspace
« Reply #16 on: January 15, 2009, 03:50:55 pm »
Sorry for the delay guys, I have had some computer issues that I have been fighting with (darn technology!!!).
1st off, the gauges are Auto Meter Sport Comps, 2 1/16s and 3 3/8s. They are mounted in a Covan Classic panel. If you can find another panel, go for it. The Covans are junk in my book. For what I paid for the thing, I would expect better fit and a better view of the gauges. They are flimsy and just JUNK!!! When I put gauges in my 83, Im going the route I have seen on here before and use a chrome accent kit and redrill it to fit 5" and 2 5/8" gauges.
2nd off, the trans is a top loader, SM465. Its an awesome trans for an offroad truck or a truck that does alot of pulling. Stepside man, I dont know how well it would do for you as a street trans. First gear is 6.55:1, second is 3.58:1, third is 1.57:1, and fourth is 1:1. In my opinion for a street toploader, and I have considered and researched (lost all of the webpages I had saved with afore mentioned techno probs) this swap/hybrid is a T5. It will take two T5s to do the swap right.  First off, you must use a T5 from a camaro/bird as the clutch options are much more greater (s10s swaps are limited, 10" I belive is the biggest I found for a 14 spline s10). Also, the camaro/bird guts have better gearing with like a 2.70ish:1 first and a .70:1 OD compared to the s10's 4.1:1 first. But you also have to take an S10 tailhousing/shift tower and swap it with the camaro/bird's as the s10's is shorter and will be pretty close for our floor boards (maybe even still use a bench seat). Now I hadnt found a swap like this done on one of our trucks for pics or proof, but it is a common thing is some of the older chevys (ie 1950's era).
By the way, Chris, you may just wanna make that into a new post, I dont know...
Guys...anything?
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
