Author Topic: MPG Pt.1  (Read 186542 times)
Offline Greybeard
Re: MPG Pt.1
« Reply #210 on: March 24, 2016, 10:33:37 pm »
I guess I did miss the part about the swap. As an old timer I see mass as the only thing to get these ships moving, that would be the mass of a v-8 crank and flywheel.  ;D I know these trucks came stock with I-6 engines, and they were good engines, just don't even try to drag race a fully loaded Conestoga wagon with two ponies pulling it, you will lose every time. What you could do with those I-6's is pull a dozen of the Conestoga wagons over Donner pass in a snowstorm all at once. I see the v-6 as an entirely different animal. It's not a good high torque puller, it has no mass for it either, but they also don't have great high rpm horsepower. They are what might be called eunuchs of the automotive world. They do get good fuel mileage if the power to weight ratio is in their working parameters.
With that said, I had a new 2000 Silverado with the v-6. It was an awesome truck. But it was a standard cab, step-side. It got 20mpg easy. But it was a finicky drinker, the fuel injectors clogged every six months and had to be replaced each time. I got tired of that and sold the truck. Iowa is (was anyway) notorious for dirty fuel. It was hard to get brand name fuel around here though, just convenience store fuel.
OK, I digress....
Offline Stewart G Griffin
Re: MPG Pt.1
« Reply #211 on: April 02, 2016, 11:20:45 pm »
276.5 miles/ 16.666 gallons = 16.59 mpg
$2.119 per gallon regular at Exxon,  $35.32 to fillup.
Improving, but mostly highway miles.  And it's still lame because the 350 and 305 both could get 16.5mpg doing mostly highway miles without even trying.
Re: MPG Pt.1
« Reply #212 on: August 25, 2016, 09:33:26 pm »
i'm thinking of starting another mpg thread to keep things better organized, until then:
300.1 miles /  17.489 gallons = 17.15 mpg
$2.199 per gallon regular at Exxon  $38.48 to fillup
That's more like it.  Still tweaking the carb.
Offline berserk
Re: MPG Pt.1
« Reply #213 on: August 26, 2016, 01:23:51 am »
whats wrong with 15 mpg?
Nothing, my Crown Vic gets 16mpg :'( even worse my K10 got around 9mpg mixed driving the one time I tracked it.  :'( :'( :'(
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
