Author Topic: Need advice on engine compartment  (Read 14780 times)
Offline hotrod24
Re: Need advice on engine compartment
« Reply #15 on: June 11, 2008, 09:56:55 pm »
was it dark blue or light blue for the 78s
1978 pontiac grand prix...
« Reply #16 on: June 12, 2008, 12:42:16 am »
I have found the best method for a perfect end result is clean the heck out of it. Then i sand blast everything. The metal is thick enough and has enough bends, & contors in it so it shouldn't have warping issues.
 If not sand blast then oven cleaner, and lastly plenty of Castrol Super Clean, uncut strait out of the bottle. Use a spray bottle, an old paint brush, a parts washing brush, wire brush, a bottle brush etc. All of them used together is what my choices are. Then sand everything with 320, & a maroon scuffy pad. Any surface rust cover with Chassis      Saver
http://www.savesautobodysupply.com/chasissaver.html
Or POR 15, Chassis Saver is the same thing but half the price. Any bare metal should be hit with a few coats of self etching primer. Then top coat it with Imron in my opinion. It holds up the best in under hood conditions.
« Reply #17 on: June 12, 2008, 11:44:33 am »
Harold, what is the procedure you use to topcoat Chassis Saver?  I haven't ever used it but once and it was covered with Duraback not paint.  Is it like POR15?
Offline nativetexan
« Reply #18 on: June 16, 2008, 03:58:09 pm »
This might sound kinda cheesy but, What if I primed it and and painted it with a spray can app? Or rolled on with a thinner?? I mean it might look good with the spray cans from duplicolor right? Thanks for the advice so far guys.
« Reply #19 on: June 16, 2008, 04:23:24 pm »
I have rattle canned many of them, being as it isn't in the sun or weather it usually comes out ok. Not necassarilly show quality, but if done with care, comes out nice.
