Author Topic: Aluminum heads  (Read 10730 times)
Offline Layne
Re: Aluminum heads
« Reply #15 on: July 12, 2008, 11:57:42 pm »
Good point. lol never thought of that, and I found those trick flow heads to be $900!!! So I'll probably jus pop the rockers and see what I can do. Thanks
Offline TexasRed
Re: Aluminum heads
« Reply #16 on: July 12, 2008, 11:57:54 pm »
Perhaps make sure your exhaust is on tight too.
Offline Dragon
Re: Aluminum heads
« Reply #17 on: July 13, 2008, 12:49:24 am »
Guy i bought it from put a new stock cam in it and when he put the covers on he put the oil cap in and all the other holes on the rocker covers were exposed. so its got a valvetrain clatter and if i gotta fix that it would just make more sense to put a set of assembled heads on her...
I can't make sense of what you are saying here. Regardless if you put any heads on it you will have to adjust the valvetrain accordingly.
Oy Vey! It's all Yiddish to me too, but I will give it a try! :-X  Sounds like the previous owner put back the Oil Cap on the Valve Covers, but left out the Crank Case Breather Grommet,Crank Case Breather,PCV Grommet, and PCV along with the associated Breather Tubes/Hose....  To give you a bit more of assistance, I would suggest you post pics of your Valve Covers, and Engine Bay, so we call help you Identify what all you would need to pick up....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
