Author Topic: changing diff gears  (Read 11729 times)
Offline SUX2BU99
Re: changing diff gears
« Reply #15 on: August 25, 2008, 11:47:02 am »
^ Righto. A good way is to do the trick of putting both wheels in the air and if you spin one tire and the other spins in the same direction, it will be a functioning posi. If you spin it and the other spins the opposite way, then it's either an open diff (non-posi) or it's a worn-out posi. The 3.40 posi I just put in seems to be worn out since when I do that tire spin trick, it goes the opposite direction  :(
Offline chrpmaster
« Reply #16 on: August 25, 2008, 01:08:44 pm »
Just today I swapped the 4.10's in my shortbox out for a rear end with 3.07's.
So did you swap the entire rear end or just the final drive?
Offline bob77
« Reply #17 on: August 25, 2008, 01:28:34 pm »
I swapped the entire rear.
