Author Topic: My engine needs diapers.  (Read 12704 times)
Offline Leevon
  • "Common Sense Ain't So Common"
Re: My engine needs diapers.
« Reply #15 on: March 21, 2009, 09:51:45 pm »
Good there's a Carquest next town over.
1950 3100
1971 Cheyenne
1987 Silverado
2018 Silverado
Offline Leevon
« Reply #16 on: April 06, 2009, 08:17:00 am »
Got it!  I pulled out the two lower bellhousing to engine block bolts on the passenger side and cleaned them.  When I sprayed brake cleaner into the second bolt hole, nothing came back out, not a drop!  I put a generous amount of thread sealer on the bolt, let it sit for a day and then drove it to work this morning.  NO LEAKS, NONE.  Must have gotten into an oil passage?  I wonder if there was some debris in the hole and it pushed through when I tightened the bolts after swapping the trans.  Whatever, it's done.  I can park in my driveway now ;D ;D ;D ;D
« Last Edit: April 06, 2009, 08:18:41 am by Leevon »
1950 3100
1971 Cheyenne
1987 Silverado
2018 Silverado
Offline nativetexan
« Reply #17 on: October 06, 2010, 10:09:32 pm »
I am having a similar issue. SO, m question is... how can oil come from anywhere concerning the bellhousing? Is that what you meant by 'getting into a oil passage'?? My leak is showing up on both sides if the engine. Does this mean that I might have more than one bellhousing bolt causing problems? I am also considering the idea that the distributor gasket is compromised in some way... If anyone sees this, please let me know.
Offline screamin86
« Reply #18 on: October 06, 2010, 10:43:48 pm »
I'm having similar issues but I suspect my cheap valve covers are the problem.
86 ta:lm7 hot cam boltons
