Author Topic: Dual Gas Tank Operation?  (Read 20544 times)
Offline Tony_SS
« on: December 02, 2008, 08:47:07 am »
Hi, so I'm new to these trucks (just got one yesterday) and I need to know the the dual tanks operate? I have a switch labeled L and R. Right now its on L. But I notice the gauge sometimes shows half a tank, then 3/4? it seems to be reading incorrect at times?? Can someone give me a basic rundown? Thanks
1986 Silverado SWB 2WD
350 TBI / 700-R4
Offline Tony_SS
Re: Dual Gas Tank Operation?
« Reply #1 on: December 02, 2008, 11:09:11 am »
Opps I posted in the wrong section... can a mod move this?
350 TBI / 700-R4
« Reply #2 on: December 02, 2008, 02:02:53 pm »
Incorrect when driving, or incorrect at different times of the day?
Offline Tony_SS
« Reply #3 on: December 02, 2008, 03:38:25 pm »
When driving...
350 TBI / 700-R4
Offline DnStClr
« Reply #4 on: December 02, 2008, 06:08:25 pm »
There's a switching valve under the passenger door frame rail. When you operate the switch on the dash, the valve closes the electrical circuit to the first tank you were reading and opens the circuit to the other tank. If both right and left tanks are full, what does the gauge indicate when you switch tanks?
Don
87 Chevy Silverado
Offline Tony_SS
« Reply #5 on: December 09, 2008, 11:31:46 am »
Never had both tanks full....
What happens when I flip the switch? Does the gauge just switch over and rear whats in that tank?
350 TBI / 700-R4
Offline klineks
« Reply #6 on: December 09, 2008, 11:47:47 am »
I too have dual fuel tanks and my gauge does the same thing.  I think it is because there are not enough baffles inside the tank to keep the fuel from sloshing around.  That in turn causes the float attached to the sending unit to always be changing with the movement of the fuel.  I always check the gauge when I have been stopped for about a minute.
Offline 79scottsdale
« Reply #7 on: December 09, 2008, 12:09:00 pm »
If you kneel down on the passenger side of the truck (at the rear of the door) and have someone flip the switch, you will hear an audible click from the valve when you switch tanks. Our guage is also all over the place when making turns, heavy acceleration, etc.
Working on the truck with my son.........Life doesn't get any better than that!
1979 Scottsdale C10 4X4 (We are the second owner.)
Offline bigblue09
« Reply #8 on: December 11, 2008, 10:20:44 am »
when im driving it will move around a lot. like from 1/2 to empty. but when im stopped it will stay in one place.
'87 Silverado EFI 305
Offline Bubba13
« Reply #9 on: December 24, 2008, 02:43:32 pm »
Yup that was a poor design. I have the same dual tank setup also. My guages are all over the place also.
Watch where you're going, remember where you've been...
Offline treepete
« Reply #10 on: December 31, 2008, 10:09:14 pm »
Does the fuel gauge in the dash also change which tank it monitors somehow?
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline DnStClr
« Reply #11 on: January 01, 2009, 11:31:39 am »
The gauge doesn't change anything guys. It only reacts to a change in the electrical signal that's sent to it. Or I should say- it changes according to resistance that the sending unit senses.
Don
87 Chevy Silverado
« Reply #12 on: January 01, 2009, 05:26:16 pm »
True, but I think treepete was asking if the guage can read each tank separately, and the answer is yes. Unless something is wrong, the guage will give you the tank fuel level of whatever tank you have selected with your switch, i.e. L or R.
Offline Tony_SS
« Reply #13 on: January 01, 2009, 09:40:11 pm »
Mine does not. It seems to only work on the left tank. Do you have to restart the truck with the switch flipped? or should the gauge change instantly with the switch?
350 TBI / 700-R4
Offline bigblue09
« Reply #14 on: January 01, 2009, 09:56:31 pm »
if your sitting at idle it should just switch.
