Author Topic: 305 to 383 stroker!!  (Read 7060 times)
Offline bigblue09
« on: December 08, 2008, 12:02:39 am »
i just saw a rebuilt 383 stroker on ebay for 2000. i have the stock tbi 305 in there now. the 383 says 87 tbi. will all the parts fit the 383? like valve covers, intake manafold, and everything else needed.
'87 Silverado EFI 305
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 305 to 383 stroker!!
« Reply #1 on: December 08, 2008, 05:37:09 am »
I'd go with a dual plane aluminum intake myself, well, I did.  Most things should bolt right up.  I went froma 350 to a 383, since a 383 is a 350 block, it all matched, including starter, alt brackets, ps brackets, ac brackets, etc.
most things should bolt right up from a 305.  Whatever the difference b/w  a 305 and 350, well, you may have a problem. Valve covers should be fine.   There are some instances when a 305 starter is different.  The 383/350 should take a  diagonal bolt pattern starter.
Offline bigblue09
« Reply #2 on: December 08, 2008, 11:13:25 am »
oh ok. thanks.
Offline DnStClr
« Reply #3 on: December 08, 2008, 11:33:23 am »
I think you'd have to get bigger tbi injectors to get full use of the 383.The injectors on a 305 are flow rated at 40 lb/hr and on a 350 they're 55 lb/hr.
Here's a pretty good link to keep around- http://www.cfm-tech.com/index.htm
Don
87 Chevy Silverado
Offline bigblue09
« Reply #4 on: December 08, 2008, 04:57:42 pm »
i dont really plan on getting it as much as i would love to. i was just wondering what all i would have to change from the 305 to the 383 if i were to get it.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #5 on: December 08, 2008, 09:32:18 pm »
trust me, you wouldn't be disappointed.  They don't call these things stump pullers for nuttin  www.delbridge.net/install
Offline bigblue09
« Reply #6 on: December 08, 2008, 11:33:20 pm »
i know i have heard a lot of good things about them i just really dont have the money for it.
Offline bigblue09
« Reply #8 on: December 09, 2008, 12:31:38 pm »
wow. thats crazy  ;D. my rearend couldnt handle that much power. lol
