Author Topic: 03-04 Silverado Seats?  (Read 54009 times)
Offline Skunksmash
Re: 03-04 Silverado Seats?
« Reply #30 on: August 22, 2009, 03:04:16 pm »
I take it you had to run a bunch of new wires under the carpet? I'm sure you can do the heat part of the seats, but i think for cooling you will have to run some new air conditioning ducts to the underside of them.
Offline DFAA
« Reply #31 on: August 23, 2009, 02:43:05 pm »
I only ran 2 wires, a 10g hot(connected to both power wires under seat) and 1 ground. Actually, I ran wires to a junction block between the seats, and forked off of that to each seat.
Interior was bare at the time, so running the wires was no problem. The "cooling" part of the seats is simply a fan that circulates air(perforated leather helps), I dont think they are hooked into the AC system at all. Only good for about 15 deg. temp drop, or so I have read.
