Author Topic: Need 4x4 floor pics please  (Read 6724 times)
Offline topside
« on: December 11, 2008, 10:38:15 am »
Trying to get an idea of how much of my '79 K10 floor I need to save, and how much of my '83 C10 floor I don't need to clean up, for teh eventual swap in the Spring. Anyone have 4x4 floor pics they can post? I'd appreciate seeing them, thanks.
Offline hotrod24
Re: Need 4x4 floor pics please
« Reply #1 on: December 11, 2008, 12:27:29 pm »
this might help you out i know these are not the best pics but they might help if you need more let me know and i will take a few
« Last Edit: December 11, 2008, 12:41:24 pm by hotrod24 »
1978 pontiac grand prix...
Offline topside
« Reply #2 on: December 11, 2008, 12:40:34 pm »
Thanks, man, that helps! I didn't see anything when I did a search, but knew there had to be something posted.
Offline hotrod24
« Reply #3 on: December 11, 2008, 01:17:34 pm »
 any time
« Last Edit: December 11, 2008, 01:20:10 pm by hotrod24 »
« Reply #4 on: December 11, 2008, 05:59:47 pm »
Here is some of a floor I redid a few years ago.
« Last Edit: December 11, 2008, 06:01:39 pm by Blazin »
Offline joesgarage71
  • Wrench
« Reply #5 on: December 13, 2008, 01:49:06 pm »
 Heres a pic of the under seat 4X4 hump. This piece was cut from a 4X4 cab floor and used to convert a 2WD cab to 4X4, it's part one in the hole you need to cut in the 2WD cab floor. It is installed from underneth and bolted/screwed to the floor and the transmission hump bolts in last from the top.
This is the hole that was cut in Old Rusty's cab. I'm replacing the cab so I will do the same thing to the new  2 WD cab(I could weld it in, But its only a mudd truck)
« Last Edit: December 14, 2008, 07:45:34 pm by joesgarage71 »
