Author Topic: rear end  (Read 5368 times)
Offline hotrod24
rear end
« on: December 17, 2008, 06:21:27 pm »
how would i do a normal rebiuld for a 78 chevy
1978 pontiac grand prix...
Re: rear end
« Reply #1 on: December 17, 2008, 06:35:02 pm »
As in replace all the internals?  You would need some dial indicators to set it up in the end for the gears.
Offline hotrod24
Re: rear end
« Reply #2 on: December 17, 2008, 06:41:45 pm »
i mean to just freshing things up how would i go about that?
« Last Edit: December 17, 2008, 08:18:55 pm by hotrod24 »
Offline hotrod24
Re: rear end
« Reply #3 on: December 17, 2008, 11:04:50 pm »
how can i find out what gears i have it is a 14 bolt
Offline joesgarage71
  • Wrench
Re: rear end
« Reply #4 on: December 18, 2008, 08:47:44 am »
 Should have a sticker in the glove box with options on it. If not you can count the teeth on the gears/there should be a stamp on the outter edge of the ring gear with the number of teeth divide them and you'll have the ratio.
 If there nothing wrong with the rear end  just replace the bearings and seals/gaskets.
 "If it ain't broke don't fix it"
Offline hotrod24
Re: rear end
« Reply #5 on: December 18, 2008, 10:57:29 am »
ok thanks
