Author Topic: Caltracs Traction Bars  (Read 46540 times)
Re: Caltracs Traction Bars
« Reply #15 on: December 27, 2008, 09:42:30 pm »
Mine is flipped also and there is no welding required.  You just use the saddle mount for the flip for a kit.  I HIGHLY recommend notching the frame if you ever intend to carry anything in the back.
Offline grinder1989
« Reply #16 on: December 27, 2008, 11:44:31 pm »
I'll be using my truck for the strip for the most part.  I'll have about 600 pounds in it but manly just at the strip.  Would stiffer springs help out?  What shocks should I use after I flip it?
Sundown Authorized Dealer, Akron OH
« Reply #17 on: December 28, 2008, 08:36:12 am »
I flipped mine and used shock extenders with lowering shocks. I also replaced my leaf springs but removed the overload spring. It made a huge difference and I would recommend replacing the factory worn out leaves.
Offline grinder1989
« Reply #18 on: December 28, 2008, 09:17:35 am »
Do you hit the frame at all?
« Reply #19 on: December 28, 2008, 09:24:59 am »
I moved the factory bump stops back a little bit so if I do I'll hit them first. I did hit the bump stops before I replaced the springs but since then it rides/handles nice. I do need better front shocks though. I'll see if I can snap a few pix of my set up
Offline HAULIN IT
« Reply #20 on: December 28, 2008, 01:15:24 pm »
Grinder, What are you doing with the 600lbs. Ballast?  :-\  Lorne
Offline eventhorizon66
« Reply #21 on: December 28, 2008, 01:27:06 pm »
Spare engine.  Always be prepared.
'85 C10 SWB 350 700R4 TKO600
Offline grinder1989
« Reply #22 on: December 28, 2008, 03:20:55 pm »
No decision yet.  I put sand bags in for the winter but I won't need them.  I'd like to carry things from place to place only if I have to.  I just don't want my frame to hit and I can't afford to notch it right now.
Offline grinder1989
« Reply #23 on: December 28, 2008, 03:22:30 pm »
So, new springs, new shocks, shock extenders?, moving bump stops, a flip kit and the traction bars.  As well as drop spindles for the front to even everything out.  :( I need to make some more money lol.
Offline GVazquez
« Reply #24 on: December 29, 2008, 04:49:26 pm »
So when you guys flip the rear end, you keep the Factory hangers and shackles??
« Reply #25 on: December 29, 2008, 06:29:59 pm »
Yes, no need for those with a 5-7" drop.
Offline GVazquez
« Reply #26 on: December 29, 2008, 06:40:46 pm »
glad I kept my old stuff..thanks for info
« Reply #27 on: December 29, 2008, 07:41:15 pm »
nah, he's got a Chevy...not a Ford
Offline grinder1989
« Reply #28 on: December 29, 2008, 08:49:23 pm »
I'm still confused on the shock extenders...
« Reply #29 on: December 30, 2008, 12:39:39 pm »
Shock extenders allow you to use a normal application shock on the truck instead of dropped shocks.
