Author Topic: aux fuel tank removal on SWB question  (Read 12176 times)
Offline BoobZ
« on: December 25, 2008, 08:28:56 pm »
has anyone on this board done this and if so what would i have to do to do it..
im getting a BAD old gas smell after i drive my truck a ways but i know its not coming from my main tank.. i still have the old tank and was wondering if there was a way to remove/delete it and the selector switch.. im tired of smelling old gas and i would like to remove it to get rid of some extra unneeded weight..
thanks
-bobby
Offline DnStClr
Re: aux fuel tank removal on SWB question
« Reply #1 on: December 26, 2008, 06:09:20 pm »
Bobby, did you see the post that Capt.Kaos wrote up in the "technical pages topics"?
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9294.0
Don
87 Chevy Silverado
Offline hotrod24
« Reply #2 on: December 26, 2008, 06:37:23 pm »
yea it is that easy i had dual tanks on my truck and i took both off but i am putting one back on. just get rid of the unwanted hoses and run the line to one tank and for the switch take it out and weld a peace of sheet metel back in its place and clean it up :)
1978 pontiac grand prix...
Offline BoobZ
« Reply #3 on: December 26, 2008, 07:00:51 pm »
alright thanks guys.. it is much appreciated.. ive been wanting to do this for some time now and probably next weekend will be when i get it done..
i did a serch and couldnt find anything..
thanks again for the link and replys..
bobby
Offline DnStClr
« Reply #4 on: December 27, 2008, 08:06:31 pm »
Since you have to take the old tank off, why don't you just replace it with a new tank? Why do you have a concern about extra weight?
Don
87 Chevy Silverado
Offline BoobZ
« Reply #5 on: December 28, 2008, 10:57:48 pm »
well on my truck im leaning more towards the performance side.. less weight equils better power to weight ratio..
i figure with 8 pounds to a gallon of liquid.. 16 gallons of gas is 128lbs.. that not including the weight of the tank its self..
Offline BoobZ
« Reply #6 on: January 04, 2009, 02:50:04 pm »
alright i took it out and the fuel selector valve also.. plumbed some 1/4, 3/8, and 5/16 high pressure fuel hose between the lines to complete them.. the aux tank is completely removed and so is the selector valve.. rewired the fuel guage sending unit wire and im done. there goes 50 lbs at least as well as that bad fuel smell..
thanks guys
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #7 on: January 09, 2009, 10:44:39 pm »
Did your truck come with emissisons stuff?  Reason I ask is my truck has no emissions and both tanks have a vent right at the tank, open to the air.  Everything on my truck had been redone or replaced and I still smell gas now and then because of those vents.
Offline BoobZ
« Reply #8 on: January 10, 2009, 12:54:36 pm »
yes it did.. it has 3 instead of 2 lines going to the tank(s)... i already took out my spare tank and it solved the problem, and got rid of about 150 extra lbs.
Offline DnStClr
« Reply #9 on: January 10, 2009, 12:57:57 pm »
78 Chevyrado- There should be a vent hose attached to the tank vent and hooks up to the filler neck.
Don
87 Chevy Silverado
  • Z62 ON-ROAD
« Reply #10 on: January 10, 2009, 04:32:45 pm »
Glad ya got it all fixed up and saved you some weight.
I found a pic of what I'm talking about, now bear in mind my truck never had all that emissions stuff:
That white vent is the same kind that goes on the rear axle vent line.  Its just open to the air.  I smell gas now and then from those vents.  One of the vents was missing when I took the bed off, but I found a new one.  If anybody's hunting one of those vents for their axle or something, I wasn't able to find it listed for either fuel system or axle parts.  I did find it listed under a TH350 case vent, they're the same thing.
« Last Edit: January 10, 2009, 04:35:00 pm by 78 Chevyrado »
Offline BoobZ
« Reply #11 on: January 11, 2009, 03:09:50 pm »
i think my vents go back up to the front of the truck where i assume the overflow canister would be or whatever for the emissions stuff.. i have 3 lines in the sending unit, i have a fuel line and return line from the pump on the block, and also a vent line that goes up to the front of the truck somewhere, i'd have to get under it and see. but thats what i'm assuming.. I'm eliminating ALL emissions from my truck since my area doesnt have inspections.. right now im simplifying the truck to get rid of everything i dont need, including all EGR, emissions, and A/C stuff..
Offline Prong
« Reply #12 on: January 11, 2009, 07:58:44 pm »
That other line would be a vent line to the vapor canister up front. That's the one piece of emission equipment I don't mind, because it doesn't hinder performance and it does a good job of getting rid of gas fumes from a full tank.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline BoobZ
« Reply #13 on: January 11, 2009, 09:54:29 pm »
i dont have a vapor can.. the vent line is plugged with a screw right now.. should i just get a little in-line vent for the line or should i keep it plugged?? i dont mind smelling gas.. its when i smell old gas when i start getting a lil upset..
thanks for the info guys.. never fails. :)
