Author Topic: headlight problems!!!  (Read 14239 times)
Offline bigblue09
« on: December 27, 2008, 10:13:20 pm »
 ok so for christmas i got a set of dimond cut headlights for my truck with the xenon bulbs and all. they are really good looking and really bright. we put them on on christmas day and that night the dimmer switch went out. i couldnt change it from low to high it wouldnt click. so i changed that out this morning and it all works good. then i drove it tonight and when i put my high beams on and about 15 seconds later the lights started cutting on and off like fast. they were flickering. all 4 of them were doing it. it will keep doing it when the highs are on. the lows work great. idk what it is or what to do about it. ??? please give any advice! thanks!
'87 Silverado EFI 305
Re: headlight problems!!!
« Reply #1 on: December 27, 2008, 10:17:30 pm »
Are you running relays to them?
Offline bigblue09
« Reply #2 on: December 27, 2008, 10:20:26 pm »
relays? there were little connectors for each headlight that came with the lights.
Offline joesgarage71
  • Wrench
« Reply #3 on: December 28, 2008, 09:28:36 am »
Offline bigblue09
« Reply #4 on: December 28, 2008, 10:09:47 am »
ok thanks guys. that explains everything.
Offline N2TRUX
« Reply #5 on: December 28, 2008, 12:16:14 pm »
And that mod should make them even brighter.... 8)
Offline bigblue09
« Reply #6 on: December 28, 2008, 09:19:25 pm »
good! but will the stock wiring hold up to the mods??
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #7 on: December 28, 2008, 09:45:44 pm »
Shouldn't be a problem.  In the stock configuration, all the power the lights get runs through the headlight switch and the dimmer switch (the bottleneck).  With the relays the switch and dimmer will only have to give the signal for the relays to send direct battery power to the lights.
Offline bigblue09
« Reply #8 on: December 28, 2008, 11:30:15 pm »
oh ok. that makes sense. thanks a lot guys.
Offline bigblue09
« Reply #9 on: December 29, 2008, 12:13:52 pm »
so i can really figure out exactly what relay i need. any help?
« Reply #10 on: December 29, 2008, 06:00:21 pm »
Sorry for not answering.  I have sparatic on the site since Mommy and Elizabeth is home.
Offline eventhorizon66
« Reply #11 on: December 29, 2008, 06:31:54 pm »
Any 30A Bosch-style relay ought to do it.  Like the article says just ignore the "normally closed" contact (the one in the center) if you end up with a SPDT relay like these.  A SPST relay would not have the center contact.
BTW here's a 73-87 specific headlight relay article.
« Last Edit: December 29, 2008, 06:41:53 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline bigblue09
« Reply #12 on: December 29, 2008, 09:55:38 pm »
ok. thanks. thats exactly what i bought but its 4 prong.
Offline N2TRUX
« Reply #13 on: December 29, 2008, 10:18:24 pm »
Be sure to take some pics of before and after for future reference.
Offline bigblue09
« Reply #14 on: January 03, 2009, 12:12:45 pm »
well i finally got it all wired up and everything works great now. thanks for all the help!  :D
