Author Topic: A Newbie sayin Hi  (Read 19028 times)
Offline eventhorizon66
Re: A Newbie sayin Hi
« Reply #15 on: December 29, 2008, 06:22:59 pm »
Thanks for the help and compliments, this is the first 87 I've had and I hate the lockout converter. A buddy told me you could put a toggle switch on them but I have not found out how yet, has anyone done this? If so can you tell me the wire to put the switch on. Thanks, Jerry
I had to put a toggle switch in my truck otherwise it would lockup as soon as I reach 4th gear at 40 mph (1250 rpm) and the engine hates it.  There is a wire that goes from the trans, to a vacuum switch on the firewall (near the brake booster), and then into the cab to a switch at the brake.  I simply cut it at a convenient location and put in a 15A SPST switch.  When the switch is closed it's free to lockup, when it's open, it is forced unlocked.  No problems so far.  But you shouldn't want to eliminate lockup altogether.  It's great for highway cruising.
« Last Edit: December 29, 2008, 06:25:43 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline JBerryhill
  • 1987 GMC Sierra Classic SWB
« Reply #16 on: December 29, 2008, 08:52:12 pm »
Thanks for the tip, did you cut the wire inside the truck cab or under the hood. Also do you recall the wire color? Thanks, Jerry
Thanks for the info on the dye and carpet Chris, do you know if ACC sells flat pieces of matching carpet? I would like to cover my sub box to match the carpet I order.
Offline infamouschevy
« Reply #17 on: December 29, 2008, 09:19:12 pm »
welcome from fort worth Texas 85 swb iyou have a really nice truck
infamous chevy
« Reply #18 on: December 29, 2008, 10:29:46 pm »
I cut it in the cab, nearest the brake switch and mounted the switch through a hole I made to the right of the steering column.  On my truck the wire is light blue.
Offline bigkountry
« Reply #19 on: December 31, 2008, 11:34:29 am »
Welcome from KY
« Reply #20 on: December 31, 2008, 11:59:21 am »
Just a thought on the whole TCC lockup bypass switch thing.  My mod was to a carb'd model.  If you're truck is TBI, the wiring will likely be different.  Not only that, but the TCC may be controlled entirely by the ECM (not sure about this).  So you may want to ask a pro (which I am not) before cutting away.
Offline oldyeller
  • 81 Chevy 3/4 ton
« Reply #21 on: January 08, 2009, 08:14:36 pm »
Welcome from Texas.  Nice looking truck.
1951 Chevy truck
6 extended cab square bodies
Just to name a few
