Author Topic: RetroBelt installation?  (Read 51849 times)
Offline vince311
« on: December 28, 2008, 11:12:36 pm »
Wondering if anyone has pics of their installed aftermarket 3-point retracting seat belts? I bought the RetroBelt set up...and the instructions are not great. Its unclear where the 3rd point should be bolted.
The belts I have can be seen here: http://www.trubelt.com/products/details/id/3
'82 Chevy shortwide, 2wd, 350/350 - Sold
Offline DnStClr
Re: RetroBelt installation?
« Reply #1 on: December 29, 2008, 03:16:47 pm »
Vince, did you see their link for installation help?
Don
87 Chevy Silverado
Offline vince311
« Reply #2 on: December 29, 2008, 03:20:45 pm »
yep. already went that route. they have examples of how to install in cars/convertibles...and a general install guide. I'm looking for specific examples for a chevy/gmc truck application. The more I look at it...it appears I'm going to have to create a new anchor point in the floor. Thought I would take a chance, see if anyone else on the forum had installed this type of belt before.
« Reply #3 on: December 29, 2008, 06:15:32 pm »
Haven't seen them, but I am interested.  Any pics of the seat upholstery?  Feedback?
Offline vince311
« Reply #4 on: December 29, 2008, 06:38:38 pm »
Yes! Sorry for the delay. Here are a couple pics (they don't do the truck any justice)...need to get some good ones when the warm weather returns.
Some of the work done to date includes:
- painted door skins
- installed new bench skin (thanks Chris!)
- new carpet
- replaced dash bezel
- painted various plastic pieces
- replaced steering wheel with a Grant wheel
- added rear cab speakers, using OEM style brackets
- new floor mats
- seat belts are in progress
« Reply #5 on: December 29, 2008, 06:40:42 pm »
Sweet!
Offline vince311
« Reply #6 on: December 29, 2008, 06:46:33 pm »
Sweet!
The wrinkles on the side look worse in the photos. For never having installed upholstery skin before...they came out well. The best part...the truck no longer stinks of old man :-)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #7 on: December 31, 2008, 08:57:54 pm »
I think the one on the pillar (shoulder) is one point and the other two (on the floor) go together in the same anchor point.
Here's a site with pictures
http://www.julianos.com/how2_3point74chevy.html
A pic from the site above.  Notice both lower parts goto the same bracket.
Offline vince311
« Reply #8 on: January 01, 2009, 06:34:02 pm »
Funny you sent this link...i came across this very same website, but it didn't click the first time around.
After further review of my belts, all I needed to do was twist the belt so the top most pillar connection faces the other way. Thinking outside the box :-) Waiting on an angle bracket, then I'll post pics. The belts look like good quality. Trubelt.com is where I bought them. Seemed to be the best price from my research.
« Last Edit: January 05, 2009, 11:30:11 am by vince311 »
Offline SUX2BU99
« Reply #9 on: January 05, 2009, 01:32:46 pm »
From the pic in that link, I see it attaching at all 3 factory bolt holes unless I'm seeing something your aren't? One at the floor where the retractor pod goes, one at the shoulder in the B pillar, and the third on the floor where the push-button buckle piece is. You shouldn't have to reuse any holes twice. The inner floor holes should be sorta near the tranny tunnel. The outers are near the doors.
I like the looks of that system. Much less bulky retractor housing and mine is getting beat up plus it's brown. I want black.
Offline vince311
« Reply #10 on: January 05, 2009, 01:49:47 pm »
When I initially received the belts, and installed the top most bolt into the B pillar....the rest of the connections were not pointing in the right direction (seemingly everything was twisted). I've sense "twisted" them the correct way, so that they will install similar to the pic that 78 chevrado posted.
Here is a breakdown of the various connection points. Point 1 obviously installs at the OEM location on the B pillar. Point 3 installs at the OEM location (near the tranny hump). Point 2 installs at the OEM retractor position (via an angle bracket). Point 4 appears to install at the same location as Point 2.
I'm waiting on the angle brackets to show up. Once they do...I'll install and post pics.
Offline vince311
« Reply #11 on: January 06, 2009, 01:46:17 pm »
RetroBelt Conclusion:
Belts are finally installed. Below are a few pics. Overall, I love the new look....and the small retractor is great. The buckles are old school and appear sturdy. The grade 5 mounting bracket solved the install dilemma. I did not have to drill or modify any mounting holes.
The only thing that is a bit odd, is how the belt sits when I'm in the seat and buckled. When the seat is all the way back, and the belt is buckled...the buckle rests just off center of my body, rather than at my hip. If I scoot the seat forward...this is somewhat corrected, and the buckle sits closer to my hip. So, either the receiving end of the belt is 3 or 4 inches too long...or I just need to gain some serious weight :-)  Despite the fit, I tested the belts out this morning....and they definitely work.
thanks for everyone's advice/input.
« Reply #12 on: January 06, 2009, 04:25:59 pm »
They look good!
Offline JRConnieK10
« Reply #13 on: January 06, 2009, 04:57:11 pm »
Nice, clean look.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline 69byrd
  • Haulin!
« Reply #14 on: January 06, 2009, 10:37:12 pm »
Good job with the install, they look great.
