Author Topic: BlueCollarRon's 1982 GMC Sierra Classic  (Read 40231 times)
Offline BlueCollarRon
« on: December 29, 2008, 05:38:40 pm »
Hello everyone!  I have been on the look out for a good GMC/Chevy Truck site, hopefully this is it!
I bought this truck about 2 months ago for $1,700. It is a 1982 GMC 4x4 Single Cab Sierra Classic 1/2 ton made in Canada. Out of the factory the truck had a 305eng with a 700r tranny. Now, a 350 with 350.
Not much to say, but she is a bad Truck, real torquey!  I have straight pipes that dump off before the rear axle.  Got about a 4in lift, 33in tires.  The only problem I have with it is I have a crack on one of my starter bolt holes, I have other threads going about that, its been an on going problem.
Thanks for checking it out!
« Last Edit: December 03, 2010, 11:35:00 am by BlueCollarRon »
Offline JRConnieK10
Re: 82' GMC Sierra Classic P/U
« Reply #1 on: December 29, 2008, 05:45:41 pm »
Welcome from Ohio. Nice truck. Man it looks cold in the pics.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline oldwhity
« Reply #2 on: December 29, 2008, 05:51:40 pm »
Welcome from Maryland. Nice ride.
Rob G.
81 Chevy K20 4x4 LWB stepside
« Reply #3 on: December 29, 2008, 06:20:22 pm »
Welcome to the site!  Nice truck!
« Reply #4 on: December 29, 2008, 07:51:37 pm »
Welcome from West Texas. Looks pretty cool. I had a block crack at one of the starter bolt holes. put antiseize on a bolt, put the bolt in, and had a welder friend weld the crack up. ( He used some type of special rod for cast iron). Pulled the bolt out, and never had another problem.
« Reply #5 on: December 29, 2008, 11:35:15 pm »
Thanks for all the replys, I am in Fairbanks if you guys can't already tell.
Cool man, I think I may end up doing something similar.  First I will try simple jb weld after grinding fresh the crack.  If that doesnt work I will tack weld a bolt in the hole.
Offline 82Shortbed
« Reply #6 on: December 29, 2008, 11:58:08 pm »
Diggin the 4wd man!!!!  I like it!
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline nucknoel89
  • Proud to be Canadian!
« Reply #7 on: December 30, 2008, 02:00:01 am »
Nice, can't beat a Canadain-built GMC/Chev...  ;D
« Reply #8 on: December 30, 2008, 04:41:59 pm »
At least it came from North America and not Asia.  I already have a 3/4 or full ton front/rear end that I plan on swapping with my 1/2 ton in a few months.  I have not made up my mind yet on the size of Super Swampers I want to buy, I'm thinking 36' . Here in Fairbanks Alaska, big trucks are really common, and so are hicks and mud.   ;D
« Last Edit: December 03, 2010, 11:37:42 am by BlueCollarRon »
« Reply #9 on: February 20, 2009, 01:51:55 am »
Its been a while from my last update.
The starter problem was fixed with a starter brace.
We found a stripped out power steering bolt, and a block hole was stripped out that holds the torque bar and the bell housing driver-side.
Tuesday morning driving to work my crankshaft busted  ??? ! Bad rebuild I guess, we will find out what happened as soon as we can get it in the shop in the coming week.
Not a bad deal for $200 I think.
I think it came out of an early 80s blazer, should work perfect for my truck.  Ill take lots of pictures!
Eventually we will swap out running gears!
above: A few days before she took a big crap.
« Last Edit: December 03, 2010, 11:45:17 am by BlueCollarRon »
Offline chevyman350_82
    • Car domain site...
« Reply #10 on: February 20, 2009, 06:56:00 am »
Nice truck man! good luck with the new engine.
Offline rockable
  • Truckin', like the do-dah man.
« Reply #11 on: February 20, 2009, 06:15:17 pm »
Good luck, man.  I'm glad you've got them "cold weather genes".  My "southern" genes would freeze up where you are.  I'd likely be reading books and watchin' tv all winter, instead of working on my truck.   :)
'86 SWB Silverado
Offline BigHemi353
  • Diesel Enthusiast
« Reply #12 on: February 20, 2009, 09:12:46 pm »
I like it  ;D broke crank or not :D
« Reply #13 on: February 21, 2009, 06:17:14 pm »
Thanks guys, the truck always gets peoples attention when driving in town.  The pictures of that frozen motor up top is a 350 that I can have for $200.  It supposedly ran in the last year, the guy just had a lot of money to drop a new motor in.
I am thinking about dropping in that 350 or a 400 sitting in a 79' out in the yard.  What do you guys think, a bored out 350, bored out 400, or dont bore either one?  I plan to do some serious mudding, so a bored out 350 really has my attention.  I am knew to this so I am looking for a lot of information.
Thanks!
« Last Edit: December 03, 2010, 11:48:25 am by BlueCollarRon »
Offline Prong
« Reply #14 on: February 21, 2009, 06:36:34 pm »
I'd use the 400 *if* the motor's in decent shape. If you run 9-9.5:1 compression with a decent cam and good heads, 400 horses at the crank is easy--not to mention better torque than a 350.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
