Author Topic: 1983 Chevy Stepside - Keepin' It Old School  (Read 85909 times)
Re: 1983 Chevy Stepside - Keepin' It Old School
« Reply #60 on: June 21, 2009, 10:36:15 am »
Did you shim the bed up in the front?
Offline silvrbreez
« Reply #61 on: June 21, 2009, 06:33:56 pm »
Not yet.  The droop is only apparent when viewed broadside on the passanger side.  I've pulled dimensions to points on the front and back of each side of the bed, and it's almost like it's been bent/twisted such that the back is pretty well even but the passenger front is lower.  Weird.
Offline silvrbreez
« Reply #62 on: July 20, 2009, 07:28:54 am »
I've decided to keep the truck, for now anyway.
Moving back to the bed shim situation...
I still haven't pulled the trigger on trying to line it up, but I did a little more digging and apparently this is a problem that a few other '83 c10 guys have on another forum.  I think it's just been more obvious to me since I lowered the truck.  My plan for now is to fab up a series of different plates that will sit between the frame and the mounting bracket and around the mounting bolt.  Hopefully, just a handful of 1/8" th. sheetmetal shims can do the trick.
Other stuff...
I've also been trouble shooting my A/C lately.  Seems like I had a leak at the pressure switch on the accumulator.  That's been changed by a local shop, but now I worry it may be leaking from that switch.  Took it back once already and they said it had completely drained all the R134 overnight.  They charged me back up and tried to identify the problem with no luck.  The system seems to have held freon through the weekend, but now the compressor clutch comes on sporadically.  Worry it may be leaking down again and is close enough to too low that the compressor is about to shut off.  I have about 1/2 can of R134 at the house I'll have to throw in tonight to see what happens.  If the compressor clutch stops acting funny, then I know I'm just low...if not, back to trouble shooting.  The compressor comes on whenever I bypass the pressure switch and runs like a champ, but I don't want to do that too much if the pressure is actually off.
Offline oldwhity
« Reply #63 on: July 20, 2009, 08:50:05 pm »
Glad to hear your keeping it!! :D
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline silvrbreez
« Reply #64 on: September 03, 2009, 08:53:22 am »
Figured I'd post up a few shots of the truck as it sits now.  Still haven't taken the time to shim up the bed, but I did freshen it up with an oil change, new cap/rotor kit, plugs and wires.  No pics of that yet though.  Enjoy!
« Last Edit: September 03, 2009, 01:42:27 pm by silvrbreez »
Offline 78Scottsdale
  • Light Without Heat
« Reply #65 on: September 03, 2009, 01:32:01 pm »
Those old skool Stepsides look so awesome when they have a huge lift and mud tires though man :D Especially when they are painted a camo and have loud open headers.
-The Garage-
1987 Pontiac Grand Prix 305 V8 - 67k Orig. Miles
-Looking To Buy-
1978 Chevy Scottsdale K20, 350 V8, All Stock, Rust Free Frame, New Paint, Beautiful Truck.
Offline devious
« Reply #66 on: September 03, 2009, 01:43:22 pm »
nice lookin ride man...hope someday i can get to that point on my own project trucks
love the low murdered out look
Offline 69byrd
  • Haulin!
« Reply #67 on: September 04, 2009, 07:43:30 pm »
Truck is still looking good!
Offline silvrbreez
« Reply #68 on: September 21, 2009, 09:49:02 am »
Well I had a head gasket blow on me last week.  The truck is sitting up in my garage, torn down to the block, while the heads gets rebuilt.  I wish I could just pick up a set of Vortec heads and an new intake, but unfortunately funds don't permit for that kind of splurge while I can easily afford getting them resurfaced with all new valve seals.  Nothing much to take pictures of now, just an update on the progress.
Offline eventhorizon66
« Reply #69 on: September 21, 2009, 12:35:43 pm »
That's too bad.  Now is the perfect time for it.
'85 C10 SWB 350 700R4 TKO600
Offline silvrbreez
« Reply #70 on: October 11, 2009, 08:32:14 pm »
It's been slow going, but the truck is running again, but not without questions...
I've had the heads checked for cracks (all was good) and resurfaced and all the valve seals replaced, replaced the head gaskets, torqued them down to spec, tightened the rockers down in sequence, set the timing, cranked it up, checked for leaks, and all was well....except...
When I first cranked it up, it spit some coolant/water out the driver's side tailpipe.  This is the side that had the blown head gasket.  When it did this, it blew white smoke out as well (customary with coolant in the cylinders).  I'm banking this was just leftover coolant that I wasn't able to get out the block that was just burning off.
I continued to run the engine for awhile and forgot that I needed to change the oil since it was milky and evidenced that coolant/water had gotten into it during the mishap.  So I changed the oil and ran it again in several intervals, each ranging from 5-10 minutes.
The oil appears to be pretty clear and clean now, but I'm still blowing white smoke out the driver's side when the engine gets up to operating temperatures (say 180-185 on the original elec. gauge).  No more coolant/water is coming out the exhaust, no leaks near the head, the coolant level is holding steady in the radiator, and the temperature never appears to get over the common operating temperature (doesn't appear to be overheating).  I still haven't taken it on the road, but when I start it up, I finger the throttle at the carb to cycle it through the rev range..
I'm at a loss for what could still be causing the smoke, but I have a few thoughts...
1. Maybe the cylinders that experienced the entry of coolant water during the failure are still somewhat coated and just need to burn it off.
2. Maybe the exhaust manifold and exhaust pipes on that side still have some coolant residue coating that needs to be burned off.
3. Maybe I have coolant sitting in the muffler that smokes white whenever it's heated up and the exhaust gases blow by it.
4. Maybe the problem continued deeper and I have a crack in the block.
I'm hoping for any of 1-3, and praying that it's not 4.
Experience and advice is welcome.  Let me know what you think.
EDIT: Drove it to work today...no more smoke.  I took it for a test spin last night, and after some minor adjusting of the carb/throttle return springs, things seem to be running quite well.  I'm going to keep an eye on my coolant levels and temp. gauge over the next several days to make sure all is well there, but it fell good on the way to work this morning.
Now onto the next thing...think my power steering pump has develoed a leak, ::) and I need to change my transmission pan gasket and filter ::)
« Last Edit: October 13, 2009, 09:28:09 am by silvrbreez »
Offline 69byrd
  • Haulin!
« Reply #71 on: October 15, 2009, 07:28:26 pm »
Glad to hear everything is ok.
Offline flatblack34
« Reply #72 on: October 22, 2009, 02:09:20 pm »
favourite truck on this site so far..it's similar to mine and done in a style i like..i have spider caps and i'm saving for whitewalls..
Offline 77stepside
« Reply #73 on: October 22, 2009, 03:13:25 pm »
Very Nice I'm doing something very similar on my 77 step
Offline silvrbreez
« Reply #74 on: October 22, 2009, 03:16:55 pm »
Thanks guys!
UPDATE....
I've swapped out the power steering pump and replaced my cracked coolant overflow reservoir.  I hope to get it out for a test crank and drive either tonight or tomorrow to check for leaks again.  Man, I hope I've gotten it down to a managable amount of drips again.  Feel like a cat chasing it's tail over the past month and a half or so.  I'm just ready to get it back on the road as my daily.
