Author Topic: Cant get the mirror to hug the door all the way..  (Read 18132 times)
Offline Igosplut
Re: Cant get the mirror to hug the door all the way..
« Reply #16 on: January 05, 2009, 07:47:14 am »
ok yeah, I have the small metal part, but it has been "arched" somehow from the PO torquing too much or something.
I do NOT have that piece that appears to go inside the door itself. can you tell me a bit about that part or part set>? Im looking at my   mag now and I havent found it yet.
First off, look in the bottom of the inside of your doors. You just might find them there (sometimes the inside screw is not installed and when the mirror is removed the support falls down inside, and the person never takes the door panel off to see what the heck fell) I have. Second, Nothing from nothing, mounting the mirrors with even nuts/bolts/washers to just the door panel it will always flex because the door panel is too thin. Any insert put into the door skin will not let the mirror mount flush because the mirror mount is made to be flat to the door skin and by the very nature of inserts there is always an amount above the level of it's application.
Offline treepete
« Reply #17 on: January 06, 2009, 08:50:20 am »
hmm that may explain the slight arch to the outer metal piece. interesting.
Ok thanks for the link to the crush nut/jack nut.
Ill get this mirror back on as best I can.
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
« Reply #18 on: January 06, 2009, 04:49:13 pm »
The pieces on the back are the door braces.  It stabilizes the mirror.
Offline treepete
« Reply #19 on: February 11, 2009, 07:44:40 pm »
I was feeling around inside the door, and did not find the piece. Chris, do you sell this/ have one of these laying around for the passenger door?
1983 Silverado
1999 Yukon Denali
« Reply #20 on: February 11, 2009, 07:55:08 pm »
I don't have any that aren't in use.  You can email crossy and see if he has any.
Offline treepete
« Reply #21 on: February 11, 2009, 08:05:55 pm »
Got it, thanks.
1983 Silverado
1999 Yukon Denali
Offline treepete
« Reply #22 on: February 22, 2009, 06:44:30 am »
Chris, I cant get Crossys email. I searched members but couldnt find, can youplease advise?
1983 Silverado
1999 Yukon Denali
« Reply #23 on: February 22, 2009, 08:42:39 am »
It is the person I copied you on about the headlight bezels.
Offline treepete
« Reply #24 on: March 09, 2009, 10:38:07 am »
Sorry to bring this thread back, but I DID find the inner door part inside the door. Yesterday I dropped some screws down inside the door and whil lookenig with a light AND a mirror-on-a-stick, I saw the piece lodged under the window bump stop at the bottom of the door. it was stuck in there and took a good deal of wiggling to get it out.
So yeah, your suggestion from 20-odd posts ago was the answer.
so, just wanted to say thanks about that.
Pete
1983 Silverado
1999 Yukon Denali
