Author Topic: What is this Leak? pic  (Read 5941 times)
Offline treepete
« on: January 06, 2009, 09:40:36 pm »
I moved my truck after sitting for 2 weeks, and found this nice stain on the floor. Its kind of a rusty-chunklets-in-a-puddle-of-light-oiley-stuff kinda-vibe to it.
any thoughts on that?
 i dont see much leakng around from the trans area, but that doesnt mean thats not it.. maybe some spraying PS hose or something? I look, but can't find the source.
« Last Edit: January 06, 2009, 10:22:40 pm by Blazin »
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline ccz145a
Re: What is this Crack-A$s Leak? pic
« Reply #1 on: January 06, 2009, 10:14:42 pm »
what was the puddle under?
looks like brake fluid and mud to me.
Re: What is this Leak? pic
« Reply #2 on: January 06, 2009, 11:21:24 pm »
like ccz said what was it under and put something like a dollar bill next to it to show how big it is " how bad of a leak"
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #3 on: January 07, 2009, 12:11:26 pm »
maybe I'm just seeing things but looks red to me.
Offline ccz145a
« Reply #4 on: January 07, 2009, 01:50:59 pm »
the mud where I live IS red. ;D
Offline Dragon
« Reply #5 on: January 07, 2009, 02:04:59 pm »
+1 If it doesn't look like it is coming from the trans pan gasket edge, then I would ask if your truck has a Trans Cooler(Either external mount, or on the Radiator)....  If it does have a trans cooler, I would thoroughly inspect the cooler lines/connections....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline Blue 82
« Reply #6 on: January 07, 2009, 03:16:59 pm »
My truck has a mystery leak that kinda looked like that the other day minus the chunky stuff
Checked the tranny juice and was 1pt low
Looked at the front seal area, it fine.
Cooler lines check OK
Snugged all the pan bolts
Checked the shifter seal, OK
The modulator and tailshaft were clean
Wiped the trans pan clean with some Presolve, and looked for 5 minutes
then i saw a drip
turned out the pan had a pinhole
Got a new pan on the way
Offline treepete
« Reply #7 on: January 07, 2009, 04:26:46 pm »
yeah loose pan bolt, couldnt see it from this side.
1983 Silverado
1999 Yukon Denali
