Author Topic: My Blazer  (Read 11411 times)
Offline 78 Blazer
My Blazer
« on: January 11, 2009, 04:21:02 pm »
I'm Scott from PA. This is a pic of my 78 Blazer.
[attachment deleted by admin]
Offline joesgarage71
  • Wrench
Re: My Blazer
« Reply #1 on: January 11, 2009, 04:49:03 pm »
 Looks good
Offline 78BBSTEPSIDE
Re: My Blazer
« Reply #2 on: January 11, 2009, 04:50:45 pm »
Nice looking Blazer, what is the name of the shade of blue?
Offline oldwhity
Re: My Blazer
« Reply #3 on: January 11, 2009, 05:01:48 pm »
Good lookin Blazer!!
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline oldyeller
  • 81 Chevy 3/4 ton
Re: My Blazer
« Reply #4 on: January 11, 2009, 05:10:13 pm »
Welcome from Texas.  Nice blazer.
1951 Chevy truck
6 extended cab square bodies
Just to name a few
Re: My Blazer
« Reply #5 on: January 11, 2009, 05:34:39 pm »
Welcome
Offline 78 Blazer
Re: My Blazer
« Reply #6 on: January 11, 2009, 06:05:44 pm »
  Thanks,the color is a ford color from PPG acrylic enamel, it's called bright dark blue metallic. I sprayed 7 coats of blue followed by 6 coats of clear then I wet sanded and buffed.
Offline 69byrd
  • Haulin!
Re: My Blazer
« Reply #7 on: January 11, 2009, 07:05:53 pm »
Great looking Blazer 8)
Re: My Blazer
« Reply #8 on: January 12, 2009, 02:58:09 pm »
Welcome to the site.
Re: My Blazer
« Reply #9 on: January 12, 2009, 09:20:46 pm »
K5's rule, Welcome from New Hampshaa!
« Last Edit: January 12, 2009, 09:22:29 pm by Blazin »
Offline murraygmc
  • 85 gmc 4x4
Re: My Blazer
« Reply #10 on: January 12, 2009, 09:24:37 pm »
nice man
85 gmc high serria 4x4
Offline 78 Blazer
Re: My Blazer
« Reply #11 on: January 13, 2009, 09:33:05 pm »
  Thanks guys, I don't have too many pictures of my Blazer in digital, just on paper because I did most of the work about 9 years ago. I just found this site a few days ago and it has me all fired up to start working on my 1986 K10 4x4 shortbed again.    ;D
  Most of the welding is done on it except for the bed, but I'm thinking of getting a southern bed for on it. I have replaced the inner and outer cab corners, inner and outer rocker panels, I had to reskin the roof because it was rotted out. I got a roof at the junkyard for $100.00. My firewall on the drivers side was rotted out from the bottom up into the cowl several inches down from the windshield. Luckily my parts Blazer had a good firewall in it that I was able to use. Also after blasting around the rear window I found that it was swiss cheese too, I was able to use sections of my junkyard roof for it so it worked out well.
  My truck has dual gas tanks, both was shot so I got 2 new tanks plus 2 sending units for in them. The old 305 my truck had bad bearings/crank so I got a 350 horse .040 overbore 350 4 bolt main long block, and finished it off with an Edelbrock Performer EGR Intake, Edelbrock carb. and an Accel HEI distributor.
  I had my 4 speed trans. rebuilt, It got to the point it was getting harder to hold it in third gear and my clutch started to slip. I've put on new springs front and rear, shocks, 6" lift and 35" tires. I still need to get the front clip, doors, bed, door glass, windshield and interior parts.
  I'm planning on painting it Black Cherry or something close to that, with a black interior. I'll post some pictures of it when I get back to it.
Re: My Blazer
« Reply #12 on: January 17, 2009, 01:30:03 pm »
Welcome from NW Indiana, sweet Blazer
Offline bigkountry
Re: My Blazer
« Reply #13 on: January 20, 2009, 04:45:32 pm »
Welcome from KY
