Author Topic: heads with no acessory bolt holes?!?!?!  (Read 4244 times)
Offline 355shortbed
« on: January 12, 2009, 07:37:37 pm »
Are there brackets i can buy that will work to bolt up an alternator and power steering pump for heads that dont have accessory bolt holes? i guess they would bolt to the water pump?
Re: heads with no acessory bolt holes?!?!?!
« Reply #1 on: January 12, 2009, 08:32:29 pm »
Your best bet would be to look for the brackets off of a pre 70's car or truck. May have them later, but i am not sure. I dont know of any aftermarket brackets that bolt other wise, unless they are reporduction chrome versions of the original. You will have to modify the brackets if you are running headers with spacers because they botl to the exhaust flanges.
« Reply #2 on: January 12, 2009, 08:47:36 pm »
Offline joesgarage71
  • Wrench
« Reply #3 on: January 12, 2009, 09:04:14 pm »
 If you go with the early 60's brackets (stock chevy car or truck) you'll need a short water pump.
 Steve
Offline 355shortbed
« Reply #4 on: January 12, 2009, 09:19:18 pm »
heck yea the allan grove site has one for 25 buks, thatll work, just have to figure out what to do with power steering , cause a big metal box is hard to steer with out it  ;D
