Author Topic: Have Problem...Need solution.  (Read 11022 times)
Offline 85MudMonster
« on: January 15, 2009, 11:04:50 pm »
okay, here's the deal. I've got newer heads for my 350, they are off an L98 casting number 14101083, they have 72° center intake manifold bolts as apposed to the normal 90°. I can only seem to find one carbuerated intake manifold for this the Weiand 8120, but I'd like more options, does anyone know of any others that will fit these heads, or how to modify another intake to fit the 72° angle bolts.
Any help is appreciated.
Thanks,
Dan
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Last Edit: January 15, 2009, 11:58:11 pm by 78 Chevyrado »
Offline eventhorizon66
Re: Have Problem...Need solution.
« Reply #2 on: January 15, 2009, 11:53:31 pm »
Edelbrock 2104
Edelbrock 2604
Professional Products 52001 (equivalent to Edelbrock Performer)
Professional Products 52013 (equivalent to Edelbrock Performer EPS)
Professional Products 52021 (equivalent to Edelbrock RPM)
Professional Products 52026 (equivalent to Edelbrock RPM Air-Gap; pic is of the chrome version, this is actually satin finish)
Note: All Professional Products intakes fit either style head.  They include an angled spacer for 87-95 iron heads.
« Last Edit: January 16, 2009, 12:00:21 am by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: January 16, 2009, 12:03:51 am »
Check these out.
http://store.summitracing.com/egnsearch.asp?N=700+4294839079+4294925008+4294908216+4294840140+4294822065+4294903508+115+4294889131
yeah, I've seen those, I'm not looking for just any old intake manifold, it's got to fit the L98 72° center bolts.
Dan
  • Z62 ON-ROAD
« Reply #4 on: January 16, 2009, 12:06:47 am »
Check these out.
They're the same.  There's only 3 types.  The ones up to 86 (with 90 Degree bolts),  87-95(with 72 Degree bolts)  and then there's vortec (no center bolts at all)  all those in the list above are 72 degree center bolts.
« Reply #5 on: January 16, 2009, 12:08:48 am »
Edelbrock 2104
Edelbrock 2604
You may have hit the nail on the head. That's what I wanted was an intake that would work with either set of heads...
Anyone else got any suggestions as well...
Dan
« Reply #6 on: January 16, 2009, 12:11:29 am »
78 Chevyrado, thank you. I did not know that all the 87-95 heads had the 72° bolts I thought it was just the L98's that did....I learn something new everyday.
Dan
« Reply #7 on: January 16, 2009, 12:13:11 am »
As 78 Chevyrado said, all iron heads from 87-95 had the 72° center bolts, but keep in mind the 87-91 aluminum (corvette) heads had the standard 90° center bolts.  I realize you have the iron heads from a TPI F-body, but you should know this so you don't get confused while searching for your manifold.  Also it appears that the Weiand manifold you listed in your first post does not fit 87-95 iron heads according to their website.
« Last Edit: January 16, 2009, 12:17:31 am by eventhorizon66 »
« Reply #8 on: January 16, 2009, 12:20:38 am »
really? what do they fit then, because on Summit's website it's the only ones that come up when you search for 1987 350 with L98 head configuration....
Dan
« Reply #9 on: January 16, 2009, 12:27:14 am »
Summit probably meant L98 corvette head; their vehicle application guide can be screwy sometimes (I never use it).  According to the manifold installation .pdf file (right there on the Summit page for the Weiand 8120), under applications, it says that it is for all 55-86 heads and 87-91 aluminum Corvette heads.
Offline frogman68
« Reply #10 on: January 16, 2009, 10:10:14 am »
Edelbrock 2104
Edelbrock 2604
Just found the one like the Air gap one for 143
http://cgi.ebay.com/ebaymotors/Professional-Products-52026-Crosswind-Sm-Block-Chevy_W0QQitemZ370055991118QQcmdZViewItem
« Reply #11 on: January 16, 2009, 12:22:47 pm »
sweet. ;D
Dan
