Author Topic: 1975 Silverado Just getting started.  (Read 20133 times)
Offline ms4972
« on: January 18, 2009, 09:22:56 pm »
Just getting started on this.  Doing a 4-wheel "Big Brake" conversion, hydroboost conversion, tubular a-arms and rear trailing arm conversion.  I like the original patina so not sure what I'm doing for paint.
Offline 85MudMonster
Re: 1975 Silverado Just getting started.
« Reply #1 on: January 18, 2009, 09:24:13 pm »
I like the paint the way it is, it has that rat rod feel to it. It's a nice truck. like it alot :)
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline JRConnieK10
« Reply #2 on: January 18, 2009, 09:36:36 pm »
I like it, neat truck.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline 78BBSTEPSIDE
« Reply #3 on: January 18, 2009, 09:54:02 pm »
Nice project!
Offline 69byrd
  • Haulin!
« Reply #4 on: January 18, 2009, 10:56:22 pm »
Sweet project  8) I like the way it looks with that paint on it.
Offline oldwhity
« Reply #5 on: January 19, 2009, 07:13:14 am »
I would leave it patina'd also. Sweet ride.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline ms4972
« Reply #6 on: May 08, 2009, 12:34:07 am »
Here's an update.  Installed the tubular a-arms, 3" drop coils, 2" drop spindles, 1 1/4" sway bar and wheels.  Truck rides a lot better than it with the eibach coils and Bell Tech spindles.  The CPP spindles actually brought my wheels in and solved my tire rubbing issues.
The wheels measure 18x8 in front and 20x10 in the rear.  It's amazing how the wheels made such a drastic change to the look of the truck.  If I have time this weekend I'm going to install the 13" brake kit.  Will post pics.
Offline chevyman350_82
    • Car domain site...
« Reply #7 on: May 08, 2009, 07:11:01 am »
Sweet Truck!!
Offline 69byrd
  • Haulin!
« Reply #8 on: May 08, 2009, 09:34:40 pm »
That looks great! I like the staggered wheels  8)
Offline 1983stepside
« Reply #9 on: May 10, 2009, 04:00:30 pm »
wow man that truck looks awsome i wouldnt change the paint at all i love the way it looks all weathered, the wheels you have are the ones im gonna run on my stepside your truck is the first truck ive seen like ours with those wheels on and i cant wait to put them on my truck now keep us posted
Offline oldwhity
« Reply #10 on: May 10, 2009, 08:18:33 pm »
Looks great! I take it the sway bar is made for the a-ams and or by the same company. The way it mounts is different than stock. Was it a kit?
Rob G.
Offline ms4972
« Reply #11 on: May 15, 2009, 12:37:57 am »
The sway bar works with tubular arms and the stock arms.  It uses the endlink style mounting at the arm.  It does not use the stock frame mounts.  I had to knock out one of the rivets on the x-member in front of the motor and locate off of that.  Other than that it was a slam dunk.
Offline ms4972
« Reply #12 on: June 03, 2009, 11:13:14 pm »
Got off my butt and installed the Classic Performance Products (CPP) 13" big brake kit this past weekend.  Very easy install, I had already installed thier spindles on my truck.  The kit uses a bolt-on caliper bracket and a forged aluminum aluminum hub.  The zinc washed rotor slides on to the hub and the clamping is done by the big 52mm dual piston calipers.  I'm really impressed by the improved stopping power.  Very confident this kit can and will outperform any C-5 kit on the market
Offline jameswoodlee
« Reply #13 on: June 04, 2009, 04:38:43 pm »
What kind of wheels are those?
Wood
Offline 79K20
« Reply #14 on: June 04, 2009, 05:10:54 pm »
They look an awful lot like the Colorado Custom Snowmass...
http://www.coloradocustom.com/WheelDetails.aspx?WheelID=70&DivCat=4
