Author Topic: Whistlin Q-jet  (Read 3817 times)
Offline 82Shortbed
Whistlin Q-jet
« on: January 21, 2009, 11:39:40 pm »
Just curious to know, is it normal for a Q-jet to whistle when you crack the throttle a little after its warmed up?  My truck is my first Q-jet, so I don't know a whole bunch about them.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline dustystrucktoo
Re: Whistlin Q-jet
« Reply #1 on: January 21, 2009, 11:44:08 pm »
NO.
I would check the routing of your tubes.  Then I am guessing you might want to figure out if you need to just tighten it down a real small amount, or if you need to change a gasket.
grab a tube and a funnel.  Put the funnel to your ear and the tube is for locating the position of where that whistle is coming from.  Could just be a bad hose.
