Author Topic: Cold ir intake on my 81  (Read 14639 times)
Offline Uno99
« on: February 08, 2009, 10:02:40 pm »
Well is was really nice this weekend in Wisconsin so I pulled the truck out. I decided to swap out the old school accordion style CAI snorkel on my 350 air cleaner setup.  It supposed to be nice here all week so I'm also gonna get started on cleaning up some wiring and add some braided hoses to.
1981 GMC High Sierra SBO 350 LT Headers 2.5" Tru Duals, H-pipe, Flowmaster SUPER 44 Mufflers 2000 TCI Stall PICS http://www.cardomain.com/ride/2410355
Re: Cold ir intake on my 81
« Reply #1 on: February 08, 2009, 10:10:41 pm »
That looks real good my friend. Well done.
Offline eventhorizon66
« Reply #2 on: February 08, 2009, 10:52:42 pm »
Cool 8)
'85 C10 SWB 350 700R4 TKO600
Offline gold84gmc
« Reply #3 on: February 09, 2009, 02:06:58 pm »
how did you get the air cleaner with 2 inlets?...ive been wanting to do the same thing to my truck
92 buick century custom 3.3L
Offline Unofficial
« Reply #4 on: February 09, 2009, 09:57:36 pm »
That's funny, I did a bunch of my work to my truck because of the nice Wisconsin weather also. Looks good!
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Offline Uno99
« Reply #5 on: February 09, 2009, 10:00:49 pm »
Not sure about the air cleaner.  It an Olds 350 from a tornado swapped in by my uncle years ago.
Offline campcrf
  • stroked
« Reply #6 on: February 09, 2009, 10:29:01 pm »
cool idea.... does it make a difference?..... do you put cone filters on the end of the tubes or just have them open and use the stocker?
Offline 4x4orbust
« Reply #7 on: February 09, 2009, 10:33:16 pm »
i have a similar air cleaner, i was told (by previous owner) it came out of an old corvette. altough instead of 2 round inlets, i have 2 roughly 4 inch long, 2 inch tall oval inlets.
nice mod, looks great!!!
 i'm gonna look into something like that for my 82,  although mine will be snorkels....  ;D
« Last Edit: February 09, 2009, 10:35:01 pm by 4x4orbust »
« Reply #8 on: February 09, 2009, 10:36:47 pm »
Both HAULIN IT and I have made our own dual snorkel air cleaners out of two factory units.
Here's mine: http://forum.73-87chevytrucks.com/smforum/index.php?topic=9131.0
Check out HAULIN IT's here: http://forum.73-87chevytrucks.com/smforum/index.php?topic=6917.0
I've even heard of people doing it with large tin coffee cans.
« Last Edit: February 10, 2009, 11:54:21 pm by eventhorizon66 »
Offline Uno99
« Reply #9 on: February 10, 2009, 11:43:58 pm »
They are open with mess screen up by the inlets by the grill and a K&N filter in the stock housing.
Offline campcrf
  • stroked
« Reply #10 on: February 11, 2009, 12:42:03 am »
right on ....  good idea
Offline Cowman85
« Reply #11 on: March 01, 2009, 05:54:43 pm »
I have an 86 350 with the tall air intake, i have been wanting to install this dual intake system for a while.
Is it possible to just weld another intake on the housing?
The way my engine is setup it would have to be at a different angle on the other side since there are 2 aluminum lines sticking up in the way.
Any suggestions or thoughts?
86 C20 350/TH400 LWB
80 C2500 350/Muncie SM465 *gone to heaven* LWB
98 Malibu 3.1 V6
86 S10 L99/4L60E
« Reply #12 on: March 01, 2009, 06:26:27 pm »
Yes you can absolutely.  That's what HAULIN IT did.  I just drilled a small hole in each corner of the new snorkel, and attached it with button head bolts, along with a bead of JBweld all the way around.  I had to bend the aluminum AC compressor lines foward a little bit (it's easier than you think, but be carefull not to bend them too much or to allow them to bend at all where they are brazed to the block that bolts to the compressor).  But if you can squeeze the inlet hose between the master cylinder and AC lines by simply "clocking" the snorkel around a bit, just do that.
When you go to the salvage yard, don't just grab another air cleaner.  Be sure to grab the inlet hose and plastic baffle that mounts in the radiator support, as well.  It's a fun project, and not hard at all.
Offline Cowman85
« Reply #13 on: March 01, 2009, 06:30:38 pm »
perfect, i've already grabbed the hose and plastic piece, but i will need to take another air cleaner to cut off the metal intake so i can mount it. Would it be hard to break this off at the junk yard? it looked kinda like it was welded but i can hope.
98 Malibu 3.1 V6
86 S10 L99/4L60E
« Reply #14 on: March 01, 2009, 06:51:48 pm »
On mine, there were spot welds at all four corners that had to be drilled out (I think it's the same in your situation).  You have two options here for removing the snorkel.  You can drill out the spot welds.  Or you can cut a rectangular area immediately around the snorkel to remove it, giving you more meat to attach it to the air cleaner.  I went with the first option as I thought it looks a little better, but you have to be careful not to remove too much material while drilling/grinding, so you have plently of meat at the corners to attach it with.  You also have to be careful not to cut the inlet hole in the air cleaner too large.  Applying a bead of JB Weld and attaching the snorkel with small bolts or sheet metal screws through the holes you made removing it, works great.  The snorkel I attached feels more sturdy than the one that was already there.  Good luck.  I can post more pic on my project thread here, if you want a better idea of how to do it.  We've kinda hijacked Uno's thread.
