Author Topic: ignition help  (Read 29840 times)
Re: ignition help
« Reply #15 on: February 15, 2009, 07:59:56 am »
Take a look at the teeth on the flexplate. See if any of them are damaged.
Offline 79k10+85k5
Re: ignition help
« Reply #16 on: February 15, 2009, 02:49:18 pm »
thay aint messed up  thats the first thing i checked.  i shimmed it down and it aint bad now  i think i need one more to make it perfect tho
Re: ignition help
« Reply #17 on: February 16, 2009, 01:13:45 am »
I'm thinking more to the effect of the starter going up since it worked b4 with no problem and now sitting it wants to be stupid almost like the spindle isn't kicking out far enough, not even sure what its called the gear in the starter thats kicked out buy the solenoid
Offline 79k10+85k5
Re: ignition help
« Reply #18 on: February 16, 2009, 09:34:18 am »
should i just try a diff. starter then?
Re: ignition help
« Reply #19 on: February 20, 2009, 12:28:02 pm »
10-4
Re: ignition help
« Reply #20 on: May 29, 2009, 10:22:43 am »
thanks for the reply eurolarva so far so good the only thing left is 1black 2 whites 1 purple.    the letters i have left is.. i  and 2m,s     I put black to the one m   both whites to the other m and the purple to i    on back of the switch package it said i =ignition solenoid  m = magneto& ground. s= start  b= battery     I have no tach and no blue wire  a little more help and i think i will have it.
_______
=== XRumer 5.0 Palladium RULEZ! ===
Re: ignition help
« Reply #21 on: May 30, 2009, 02:06:10 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10150.msg92782#msg92782
 Re: trucks got a home
« Reply #28 on: May 26, 2009, 23:08:00 »
ok for the past few days i have been shoveling mud off the bank all it has done here is RAIN and there is a big mud hole under my truck  so i have been shoveling mud and shoveling and i found a big rock that goes from one end to the other so i am going to drill it out and build a wall out of 6x6s around the carport and that should take care of that then i need to clean up my tools and parts and it is back to the truck and tear down until i can get concrete and close it in i will have pics of the progress
 Report to moderator    Logged
i have a 78 1/2 ton chevy truck and i am restoring it from the ground up
MagicOPromotion
New Users
 Offline
    trucks got a home
« Reply #29 on: May 27, 2009, 08:04:55 »
w00t I passed many a truck today. Few were lit up like christmas trees as it was daylight but still. Trucks.
 judging by his other post hes eather a bot or he's just on crack. no offense to the crack users ;)
