Author Topic: Ford SD wheels on my K-20  (Read 11506 times)
Offline farmallgray
« on: February 10, 2009, 11:32:34 am »
I put a set of 99 & up ford wheels on my K-20 with 88-89 chevy center caps. To me they look like the factory alloy wheels used on the 1/2 tons. I did just have steelies with trim rings and center caps.
Now, before anyone runs out to buy a set, they do not bolt right on. The newer fords have a different 8 lug bolt circle.
I had to have the wheels redrilled to make them fit. I bought the wheels on ebay and with shipping and the machine work I have about $100 less in them than a set of new American Bajas.
1979 K-20 350/TH400
Re: Ford SD wheels on my K-20
« Reply #1 on: February 10, 2009, 12:28:03 pm »
That looks sharp
Offline campcrf
  • stroked
« Reply #2 on: February 10, 2009, 01:37:35 pm »
I made the same mistake when i bought some duramax rims for my superduty... dodge and chevy 8 bolts are the same but the ford is in mm... go figure...lol
    Looks good on your truck.
Offline 79K20
« Reply #3 on: February 10, 2009, 02:27:42 pm »
Lots of people make that same mistake. The wheels look the same, and they will even fit over the studs if you push hard enough :)
I worked at a tire shop for 4 years and saw this probably a hundred times. All older 3/4-ton and 1-ton trucks use the 8-on-6.5in bolt pattern, but the 1999-newer Fords are 8-on-170mm (~5 mm larger diameter than 6.5-inches). Pre-99 Fords have the same 8-on-6.5 that GM and Dodges use. Not sure why they changed... Stupid fords.
When you had yours re-drilled, did they drill the new holes with tapered seats or did you use the Ford pressure-seat lugs with new studs? I was told once by a Ford drivetrain rep that they HIGHLY recommended against drilling/tapering the 99-newer wheels because of issues with the aluminum (thickness, alloy type, heat-affected zone, etc). He said that if you MUST re-drill the wheels, you should also replace the wheel studs to accept ford pressure-seat lugs instead of the standard tapered lugs that you would otherwise use.
Just curious. If I were you, I would re-torque them regularly...
Offline campcrf
  • stroked
« Reply #4 on: February 10, 2009, 06:01:59 pm »
nope...I ended up selling them to another guy cause I was told not to redrill holes... but ended up winning in the end... made a little $$ on them, but now I know if i find another set i can drill them anyway... The only thing is i would be afraid of the streingth... It's an 01 f350 crew longbed we use for camping and towing the 81 around...  I guess I'll just keep useing the stock rims and buy some 35"s instead.
    :D
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: February 10, 2009, 06:14:36 pm »
Much improved!   that looks sharp!
Offline oldwhity
« Reply #6 on: February 10, 2009, 06:35:24 pm »
It does look sharp. Nice rig too I've never seen it before.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline farmallgray
« Reply #7 on: February 11, 2009, 11:25:23 am »
Thanks for the nice comments. I have been on here a while but this is my first time posting any pics.
I had them do cone seats for the stock tapered seat lug nuts (only about 1/4" deep). My Center Lines on my 88 C1500 have much thinner webs than these and are only 5 bolt and are tapered seat and I have never had any problems with them. I have always been careful torquing and retorquing them and plan to do the same on this truck. I thought pretty hard about it and consulted the machine shop and an engineer friend before having them drilled.
I planning on painting the truck again in a year or two. I looks ok in the pics but its getting a little rough around the edges. The paint job is from 1997. The hood is rotted at the front and the bedside are getting a little rust in the usual places. I have a cowl hood to put on it too.
« Last Edit: February 11, 2009, 11:29:01 am by farmallgray »
1979 K-20 350/TH400
Offline campcrf
  • stroked
« Reply #8 on: February 11, 2009, 02:25:31 pm »
right on....   are you sticking with the same color?.... cowell hood will look sweet on that beast....   Good job so far...
Offline HAULIN IT
« Reply #9 on: February 11, 2009, 09:47:40 pm »
Farmall, How did they go about doing that? Did they counterbore off-center to the original holes when installing the inserts to line up with the GM pattern? Lorne
Offline farmallgray
« Reply #10 on: February 13, 2009, 03:22:20 pm »
I'm getting rid of the pruple. The teal color will be where the purple is now, and where the teal is now will be a lighter blue maybe like a silverish blue. It should have a similair look to the 78 chevy sport 3 tone pattern.
1979 K-20 350/TH400
Offline farmallgray
« Reply #11 on: February 13, 2009, 03:24:35 pm »
I'm not quite sure I understand the question. They just drilled new holes in between the original ones. So now the wheels have 16 holes.
1979 K-20 350/TH400
