Author Topic: Will an oval port manifold fit my 454?  (Read 7055 times)
Offline 1976Scottsdale
« on: February 10, 2009, 09:41:43 pm »
Okay so I got my 454 home and was wondering, since I have pulled the intake a verified that it has the peanut port heads on it, I was wondering if an oval port intake will work with those heads or does it have to have an intake for the peanut port heads?  I plan to at some point get some better heads, but for the first year or two this thing is around... mostly while I finish school, it has to keep the peanuts.
Offline 80stepsideguy
Re: Will an oval port manifold fit my 454?
« Reply #1 on: February 11, 2009, 02:41:03 am »
I think it is the same but you probably wont get the perfomance your looking for with them heads.Look for a set of 781 or 049 oval port heads.Those i am told are good heads for a big block.And square ports are good for 1/4 mile and higher RPMS.IIRC
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #2 on: February 11, 2009, 11:03:26 am »
There isn't a specific aftermarket "peanut" port intake, so use the Oval.  I ran mine that way for a couple years until I got better heads.
« Reply #3 on: February 12, 2009, 01:04:16 pm »
Cool. I Found One Peanut Port Aftermarket Intake In Jegs But I Would Prefer Not To Buy Two Intakes If I Can Use One For Both.
« Reply #4 on: February 12, 2009, 01:29:43 pm »
If you put the peanut port on a set of open chamber oval port heads the performance will still not be as good.Its like sucking a golf ball thru a garden hose(full metal jacket quote). Your better off staying with a stock intake for now or look on craigslist for a set of heads.I`m sure theres a set in your area for sale for like 300.00-500.00.
thanks
pat
p.s. i know you already know this but  remember big blocks ARE NOT CHEAP. I am piecemailing mine little by little before you know it you`ll have a engine that runs like a raped ape.
