Author Topic: tail light  (Read 3929 times)
Offline tuptup
tail light
« on: February 12, 2009, 04:16:37 pm »
my passenger tail light dont work the wireing messed
its the taillight, brake light and signal all in that main light
anyone got a diagram so i know where to trace it back too
82 k10 lwb fs
riding high
Offline hotrod24
Re: tail light
« Reply #1 on: February 12, 2009, 05:05:56 pm »
will this help
« Last Edit: February 12, 2009, 05:13:00 pm by hotrod24 »
1978 pontiac grand prix...
Re: tail light
« Reply #2 on: February 12, 2009, 08:51:07 pm »
Pull the lens, then the light socket. if none of them are working I would say it the ground or the light itself. Not going to be a fuse if the other side works all functions. See if the ground is hooked up. Might have rusted or broke off. Next check the plug under the bed behind the bumper. If its plugged in check it for corrosion. Unplug it and check for power with a test light. If no power trace the wires to the cab bulkhead connector under the hood behind the fuse box.
Offline bigkountry
Re: tail light
« Reply #3 on: February 17, 2009, 03:42:10 pm »
Not to over rule these guys, but it might be your pig tail (the part the light goes in to). I had one go bad otu of the blue one day. Traced the wires, new bulbs, etc., turned otu to be the pig tail itself had goen bad.
