Author Topic: Need a little help...  (Read 4280 times)
Offline Maintenanceman
  • Older is always better
« on: February 13, 2009, 02:27:59 pm »
Ok I just recently bought an edelbrock performer 750 carburetor. Ill need one that big for future plans but  for now I think Ill probably have to jet it down a little bit (probably to a 600-650). How to I figure out what size jets I will need to do this? and are holley jets the same as an edelbrock jet? By the way, I dont know that much about carburetors lol.
TIA
Offline joesgarage71
  • Wrench
Re: Need a little help...
« Reply #1 on: February 13, 2009, 03:50:35 pm »
Then run it as it came out of the box
Offline eventhorizon66
« Reply #2 on: February 13, 2009, 04:02:33 pm »
You cannot jet a carburetor down in cfm (ie: from a 750 to a 600).  The size of your throttle blades and venturi are fixed and, in addition to the flow restriction posed by the boosters, are what determine the cfm rating.  What you can do is adjust the the jetting to achieve the appropriate A/F ratios.  You are in luck, because Edelbrock carbs have to be the hands down easiest to tinker with.  Get a hold of an Edelbrock carb owners manual and read it thoroughly; it contains everything a beginner needs to know to get started tuning.
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: February 13, 2009, 04:09:10 pm »
Thats my plan as of right now and hopefully I wont have to do anything but Im just wanting to get all my ducks in a row on what Im going to have to do before I get new heads.
