Author Topic: Lesson Learned (vacuum/emissions related)  (Read 5308 times)
Offline rockable
  • Truckin', like the do-dah man.
« on: February 14, 2009, 11:49:49 am »
Since I bought my '86, it has never run right.  I had problems with idle, idle mixture, lack of power, stalling, stumbling, harsh shifting, you name it.  Nothing I ever did fixed it............until now.
Because of my never ending mission to stop all the oil leaks in the engine, I replaced the intake gaskets.  In order to do that, you must remove all the vacuum lines, and mine has a mess of them.  This turned out to be a blessing, as I found two problems.
First, the main vacuum source to the thermal vacuum switch had the barb broken off.  Someone had tried to secure it to the vacuum switch with a tie wrap.  Autozone had the needed replacement for about $15.
Second, I decided to check the vacuum lines against the schematic.  Guess what, some previous "mechanic" had changed the routing.  Likely, because he forgot how they were supposed to go.
So, after straightening all that out, I now have a smooth running 305.  It's not a rocket but it sure is more peppy than it was.
If you are having problems with the way your truck runs, I recommend tracing out the entire vacuum circuit.  Fixing it may solve a lot of problems for you.
'86 SWB Silverado
Online zieg85
Re: Lesson Learned (vacuum/emissions related)
« Reply #1 on: February 14, 2009, 12:02:09 pm »
Great news, glade you got er figured out.  Real satisfying I bet cause you did it yourself.  Congrats
Offline 82gmc3/4ton
« Reply #2 on: February 15, 2009, 09:11:06 am »
Great post. What a lot of people don't realize is that vacuum also effects their brakes. So on top of getting better performance you also get better braking when replacing your vacuum lines. I usually replace all of my hoses every year or two. Its cheap insurance.
Offline TexasRed
« Reply #3 on: February 15, 2009, 10:51:27 am »
Where do you get the connector for the Thermal vacuum switch? My TVS broke off and I've just got everything hooked up to straight vacuum.
Offline rockable
« Reply #4 on: February 15, 2009, 06:04:17 pm »
I'd try the Chevy dealer.  If they don't have it, you probably will have to just buy the little straight connectors at the AutoZone and hook them up individually.  Make sure you get them right.
I spent a good bit of time at Napa and they couldn't hook me up with tees, elbows, etc.  We looked through a bunch of catalogs and never found the molded fittings.  This stuff is getting hard to come by.  Pehaps we'll all have to remove our EGR and AIR.   :)
My connector was ok.  The barb on the TVS that the connector pushes over was broken off.
'86 SWB Silverado
