Author Topic: Rock's '86 Silverado SWB  (Read 21818 times)
Offline rockable
  • Truckin', like the do-dah man.
« on: February 15, 2009, 11:40:03 am »
I finally got around to taking some pictures to post.  I've recently completed several projects.
 - I put a flip kit on the rear, dropped spindles and cut springs in the front.  I also installed new shocks
    and a rear sway bar.
-  I painted the rallye wheels and replaced two tires.
-  I replaced the grille and bezels.
-  I have fixed all the oil and vacuum leaks and put a rebuilt carb on it.  Fixing the oil leaks consisted of
    Intake gaskets, valve cover gaskets and pan gasket.
-  Put Pioneer CD player and speakers in.  It had original 4X10's behind the seat, so I put new Kickers in those
    housings and small Kickers in the dash.
The truck has original paint and interior.  Next up is the re-dyeing of the dash and door panels.  Whomever had it last put some sort of glossy stuff on and it looks terrible.  Also, I'm going to replace the window seals and felts.
'86 SWB Silverado
Offline oldwhity
Re: Rock's '86 Silverado SWB
« Reply #1 on: February 15, 2009, 11:42:14 am »
Man Rock, I love the clean stock look with a drop. The bottom pic lookc like calender material.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline rockable
« Reply #2 on: February 15, 2009, 11:42:58 am »
Here are some inside shots and the build sheet.
'86 SWB Silverado
Offline rockable
« Reply #3 on: February 15, 2009, 11:53:10 am »
Thanks, Whity!
I took some engine pics but the files were 134kb and won't upload.  How do I make them smaller?
'86 SWB Silverado
Offline oldwhity
« Reply #4 on: February 15, 2009, 11:56:40 am »
I put all mine on photobucket.com and download them from there.
Rob G.
Offline rockable
« Reply #5 on: February 15, 2009, 12:50:01 pm »
Ok, here are the engine pics.  Thanks, Whity.
« Last Edit: February 16, 2009, 04:53:45 pm by Captkaos »
'86 SWB Silverado
Offline campcrf
  • stroked
« Reply #6 on: February 15, 2009, 02:40:36 pm »
Wow..... is that ever clean... nice truck man.
Offline Flamingbig10
« Reply #7 on: February 15, 2009, 11:27:16 pm »
nice truck
Offline Stantonss
« Reply #8 on: February 16, 2009, 03:39:58 pm »
Very nice... Same color scheme as mine. White with red interior... KEEP YOUR DOORS LOCKED!  ;)
Your interior is in much better shape then mine.
I am wanting to change my interior to black, not sure how well that would contrast with the with metal inside.....
Very nice truck.
Offline rockable
« Reply #9 on: February 16, 2009, 03:58:24 pm »
Well, it wasn't that clean when I got it.  My wife threatened to throw my clothes away after I did the suspension and the oil leak fixes.   :)
Thanks for the compliments.
'86 SWB Silverado
Offline 73c10Shorty
  • 73 Chevy Shortbed
« Reply #10 on: February 16, 2009, 05:15:45 pm »
Very nice truck Rock! I wish mine was half as clean. Which spindles did you use and how much did you cut the coils? I really like the stance.
1973 C10 Shortbed, 350/350
Offline rockable
« Reply #11 on: February 16, 2009, 06:45:43 pm »
I used the DJM spindles and flip kit with new springs from  .  I ended up cutting 3/4 of a coil off the front springs.  There's a long thread in the Suspension forum.  Thanks!
'86 SWB Silverado
Offline campcrf
  • stroked
« Reply #12 on: February 16, 2009, 06:46:27 pm »
rock.... did you clean that engine bay up or was it like that?.. very good shape... same color as mine aswell.....   !!!!!
Offline rockable
« Reply #13 on: February 16, 2009, 06:54:47 pm »
The engine bay was pretty much like that.  I did pressure wash it.  It's a nice original truck.  That's what attracted me to it.  My father in law had an '84 that he sold before I knew he was going to get rid of it.  Ever since, I'd been looking on and off and found this one locally.  If you saw the underside, you wouldn't believe it.  I don't think it's ever seen mud.  Most of the filth I cleaned off was due to the oil leaks and dust settling on it.
'86 SWB Silverado
Offline oldwhity
« Reply #14 on: February 16, 2009, 07:13:07 pm »
That looks awesome. I noticed that your jack is on the drivers side fender weel. I guess they changed it over the years. Mines on the pass side.
Rob G.
