Author Topic: NV 4500 Swap into a 2wd crew cab  (Read 3910 times)
Offline cubicdollars
« on: February 15, 2009, 02:15:27 pm »
Just checking to see if anyone else has the same thing done to there truck as I am planning to do. I am looking for any info from people that have installed a Chevy NV4500 into a BBC powered 2wd 1 ton or 3/4 ton truck that already has excisting manual transmission. I need to know about the transmission mount difference and the drive shaft length difference.
Any info is greatly appreaciated.
I already have the tranny and I found out the front splines are the same so I will be able to use my hyd clutch assembly, I already purchased the slave cylinder and tube from master cylinder to slave cylinder.
Thanks
Dan
