Author Topic: tranny cooler lines  (Read 4823 times)
Offline nikesb1111
tranny cooler lines
« on: February 15, 2009, 07:20:51 pm »
Does the top tranny line go to the top or bottom of the radiator on an 86 k10 with a 700r4?
Re: tranny cooler lines
« Reply #1 on: February 15, 2009, 10:38:30 pm »
This question is a little confusing...  The bottom one won't be long enough to reach the top line without bending it??
Offline nikesb1111
« Reply #2 on: February 15, 2009, 11:41:17 pm »
Well im making my own lines and i forgot which ones go where. What im asking is if i start out with the top line on the transmission, where would that connect to on the radiator?
Offline eventhorizon66
« Reply #3 on: February 16, 2009, 11:58:20 am »
I doubt that it matters which way you hook up the lines.
'85 C10 SWB 350 700R4 TKO600
« Reply #4 on: February 16, 2009, 12:22:51 pm »
Top connector is the return on the 700, bottom is the feed.  If you aren't running a external cooler, it really doesn't matter, but normally the bottom goes to the top of the rad and vice versa.
