Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
Help!! no heat and its cacaca collldddd!!!!!!!!!!!!!
Topic: Help!! no heat and its cacaca collldddd!!!!!!!!!!!!! (Read 8426 times)
jefferias
February 18, 2009, 07:40:07 pm »
hi all hopefully you can help me out here. went to the truck this morning for work and all was good, till i turned my blower fan on for the heater, and nothing happened. pulled the power wire off the motor and used a mutimeter to see if power was present and it was. so i figured blower motor no big deal. picked up another unit and installed and still no worky worky. checked power again and was still there, checked power when wire pllugged onto motor and no power- unplug it and i got power. so my question is would these symptoms be maybe a "short" somewhere or the resistor unit is no good, but ifigured if the resistor was no good it would just blow on full power. really scratching my head and it's -11celcius and gettin colder
rockable
Truckin', like the do-dah man.
Re: Help!! no heat and its cacaca collldddd!!!!!!!!!!!!!
February 18, 2009, 08:28:42 pm »
Have you got a good ground for the motor?
'86 SWB Silverado
jefferias
February 18, 2009, 08:32:18 pm »
engine grounds ohh yeah i got em. bro works for electrical and got me some huge ground straps for free.
rockable
February 18, 2009, 08:36:23 pm »
No. I mean is the blower motor grounded? Take your ohmeter and check to make sure. Obviously, you've got a good ground on your meter when you check voltage. Your motor cirucuit may not have a good ground.
'86 SWB Silverado
jefferias
February 18, 2009, 08:41:52 pm »
i will pull blower motor off and lightly sand the mounting surface and try that, looked pretty good when i put on though but nonetheless thankx rock
rockable
February 18, 2009, 08:56:34 pm »
Try hooking a ground jumper wire to it and see if it runs.
That's all I got, based on the information you gave. Good luck!
'86 SWB Silverado
jefferias
February 19, 2009, 08:30:54 pm »
got it all working again !! it turned out to be the fan speed switch , which is weird cause just replaced about 8 months ago, oh well no more "jobber crap" for me haha thanx
rockable
February 19, 2009, 08:49:59 pm »
Glad you got it fixed. I don't understand why you had voltage unless the resistance was just really high through that switch, rather than open.
Oh well, at least you can be warm again!
'86 SWB Silverado
Prong
February 20, 2009, 04:30:30 am »
I had the same problem about 10 days ago and it turned out to be the resistor. I'm glad it wasn't the switch, because then the radio and bezel has to come out
Hope yours went better.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
