Author Topic: what size will fit?  (Read 5172 times)
Offline HeAvYChEvY!
  • DoWnWiTdAsIcKnEsS!
    • HeAvYChEvY!
what size will fit?
« on: February 19, 2009, 06:24:52 pm »
I need to know exactly what my options are. I want 22 inch rims with tires all the way around. Can someone tell me what i should buy, i want to be able to lower truck later on and it to tuck the rims but i dont want to bag it or cut out the wheelwells. i also want the lowest profile tire i can get where it wont look stupid? Please help! I was going to but some 305/35/23 inch rims but after chaos told me the measurements its obvious these will rub but the $1200 price with new tires looked appealing!
Re: what size will fit?
« Reply #1 on: February 19, 2009, 09:50:42 pm »
Are you wanting to run the same size all the way around?  Bags only give adjustability and ability to set it on the ground.
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #2 on: February 20, 2009, 05:37:31 am »
i want the biggest i can get that will give me this stance. Thanks Capt.
« Reply #3 on: February 20, 2009, 11:36:42 am »
That is N2TRUX pickup.  He is a member on here and a very good friend of mine.  That stance isn't the "ride" stance, that is the drop stance.  His is on air.
The rims are
Front Size- 20 x 8 Back space 5.5”
Rear Size- 20 x 9.5 Back space 6.5”
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #4 on: February 20, 2009, 08:36:53 pm »
ok but i want bigger rims? so what are the measurements with tires i need to eventually get that stance with 22's
