Author Topic: 86 c20 rear end  (Read 10083 times)
Offline Cowman85
86 c20 rear end
« on: February 27, 2009, 05:02:41 pm »
i was wondering how to find out what gearing i have in the rear end, i dont have any manuals yet unfortunately either.
its the th400 tranny, 350 4bbl, no power but a/c and cruise if that helps at all.
vin: 2GCFC24L6G 1190340
also i looked up the code on the engine and cant seem to determine if its the lt9 or hopefully the ls9.
86 C20 350/TH400 LWB
80 C2500 350/Muncie SM465 *gone to heaven* LWB
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline fitz
Re: 86 c20 rear end
« Reply #1 on: February 27, 2009, 06:00:02 pm »
Is the Factory code sticker still on the inside of the glove compartment?
The sticker will have an axle code that starts with the letter G.
GU6= 3.42 gears
GT4= 3.73 gears.
Those are the 2 of the common ones I know off the top of my head from scouting out parts trucks. If it is something else let us know and we can figure it out.
Re: 86 c20 rear end
« Reply #2 on: March 01, 2009, 07:02:08 pm »
Pull the cover (probably need to chang the old oil anyway) rotate the ring gear and find the numbers on it  XX/XX and divide.
Offline hilton850
Re: 86 c20 rear end
« Reply #3 on: March 02, 2009, 02:57:58 am »
what he said ^
'84 Sierra 3/4 ton.  4 on the floor, 4 wheel drive, upgraded to FM radio and steelhorse seat.  383 stroker under the hood - 430 hp 440 ft-lb.  custom rust holes in the bed and both rockers and cab corners.
Re: 86 c20 rear end
« Reply #4 on: March 02, 2009, 03:01:36 am »
or if you have a tac
the formula for rear ratio is
if your running 50 mph @ 2k w/ 38" then
your ratio would be about 4.53
rpms x tire size / 336 / mph = ratio
2000 x   38    / 336 /  50    = 4.53
now saying that i have 4.53 my speedo is off by 3 mph
or you could use this web site
http://www.idavette.net/tech/ratioc.htm
found them after this whole ideal about the formula
Offline Cowman85
Re: 86 c20 rear end
« Reply #5 on: April 01, 2009, 08:22:20 pm »
thanks for the info guys, i'll let you know this weekend when i finally pick her up from the shop!
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline Cowman85
Re: 86 c20 RPO ident
« Reply #6 on: April 05, 2009, 01:31:01 am »
turns out they are the GU6 - 3.42
i do have the LS9  :)
looking into the code MX1 to see if i have the TH400 (like the guy said) or the TH350.
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline eventhorizon66
Re: 86 c20 rear end
« Reply #7 on: April 05, 2009, 07:34:09 pm »
Check this out for transmission identification:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11124.0
'85 C10 SWB 350 700R4 TKO600
Offline Cowman85
Re: 86 c20 rear end
« Reply #8 on: April 05, 2009, 11:30:29 pm »
its a 400, is there that much of a noticeable difference between the 350 and 400? fuel wise and performance wise?
i read that the 400 robs more power from the engine, the 350 is lighter and one less plate so its also faster, anyone know about this stuff?
thanks
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline Cowman85
Re: 86 c20 rear end
« Reply #9 on: April 05, 2009, 11:56:14 pm »
does anyone know how much of a difference a transgo shift kit make with the th400?
98 Malibu 3.1 V6
86 S10 L99/4L60E
Re: 86 c20 rear end
« Reply #10 on: April 06, 2009, 04:08:40 pm »
If you are going to be towing the TH400 should be your choice.  It does use more power to turn, but it is also stronger.
I would add a shift kit to any trans personally.
