Author Topic: RE: DRIVELINE ANGLES:  (Read 5919 times)
Offline Stewart G Griffin
« on: February 28, 2009, 07:10:11 pm »
1) How much is too much in terms of driveline angle being hard on the u-joints?
2) Is it best to try to keep the driveline angle as straight in a line as possible----transmission output shaft as close as possible in a line with the differential pinion?
Offline Toolmaster
Re: RE: DRIVELINE ANGLES:
« Reply #2 on: March 01, 2009, 01:24:08 pm »
PT.2
How short can a  driveshaft be before things get tricky?
In other words, what i'm trying to do is get the engine/trans as far back as possible in the chassis and i was wondering how far back is too far back in terms of driveshaft length if that makes a difference.  NOTE: the crankshaft centerline will remain as close as possible to stock specs.  OR, the crank centerline will be as close as possible to the differential's pinion shaft.
« Reply #3 on: March 01, 2009, 05:51:15 pm »
Technically you don't have to have a driveshaft, but if the drivetrain is say 10" from the ground and the pinion is 2" and you have a 14" driveshaft, that is going to be pretty steep, so a normal u-joint setup isn't going to work.  You need a double cardian.
« Reply #4 on: March 01, 2009, 06:06:37 pm »
i'm going to try to have the drivetrain output centerline as close as possible to the pinion's centerline.  i was just worried about when the suspension moves up and down if having a  short driveshaft would pose any problems?   i'm estimating the shaft to be anywhere from 12"-20" ish.
Offline HAULIN IT
« Reply #5 on: March 01, 2009, 11:37:28 pm »
Stewart, Can I ask...What type of vehicle are you building & how much suspension travel will you need? Lorne
Offline hilton850
« Reply #6 on: March 02, 2009, 02:47:15 am »
Seems like I read somewhere that it depends on what universal joints you run.  I looked into the angles a couple years ago for an offroad buggy I was building.  I run spicer 1350 universals in that and the general consensus on those was you could run 7*-8* constant, up to 15* intermittant with the right yokes to prevent binding.  I wound up going with a CV driveshaft that could run double those angles...but that thing had about 20" of wheel travel and 48" driveshafts front and rear...
on a side note...sounds like you're not planning on much leg room if you're going to set the engine back far enough to make a 12" driveshaft.  what are you building?
'84 Sierra 3/4 ton.  4 on the floor, 4 wheel drive, upgraded to FM radio and steelhorse seat.  383 stroker under the hood - 430 hp 440 ft-lb.  custom rust holes in the bed and both rockers and cab corners.
« Reply #7 on: March 02, 2009, 03:17:42 pm »
Alright; i'll tell.
For a real bombshell, please go to the 73-87 trucks section and view my post entitled "C-30 SIMPLEX PROJECT."
