Author Topic: updating old chevy 4x4  (Read 9305 times)
Offline 85 1 ton 4x4
« on: March 01, 2009, 09:26:52 am »
i have a 85 chevy 1 ton 4x4.i took out the big block and turbo 400.i will be replacing it with a 2000 5.7 fuel injected and 4l80e trans out of a 2500 suburban.how many problems will i be facing to make this work.thanks
Re: updating old chevy 4x4
« Reply #1 on: March 01, 2009, 06:08:50 pm »
Being a Vortec 5.7, it should bolt right in place.  You will need the harness but every thing else should be a straight swap over.  You will need High pressure EFI specific hose and a return line.  You could run a Corvette filter with a built in regulator and only have to run one feed line to the motor, but you would have to plug the return line on the setup you have..
« Reply #2 on: March 01, 2009, 09:49:03 pm »
doesnt the 2000 sub have independent front suspension?? How are you going to change the front end, or will the 4l80 bolt up too the existing transfercase??
« Reply #3 on: March 02, 2009, 12:56:30 am »
it should be OK the 4l80 t-case went to the pas. side so it should all be in place
Offline redburban
« Reply #4 on: March 02, 2009, 11:37:40 am »
this is the same swap that i am wanting to make on my 91 burb!  keep us posted on progress would ya! is anyone else on here making the same swap? thanks
91 CHEVY K10 SUBURBAN
84 CHEVY K10 6 INCHES AND 36'S
« Reply #5 on: March 02, 2009, 05:43:18 pm »
for the transfer case i will be using the round flange 205.the computer problems is the main worry.the 4l80e was installed from factory in the 91 suburbans from what i have been told. captkoas- i have the complete harness with motor and trans.were would i find the corvette filter and regulator. choptop- yes the burban has a independent front suspension,i will stay with the solid front.i hope everything works.i will keep ya posted.
« Reply #6 on: March 02, 2009, 08:26:49 pm »
You can get the Vette filter/regulator from Autozon.  It is for the 99-up Corvette.
If you have the computer, you are already set for controlling the trans.
Offline Jay2D2
« Reply #7 on: March 02, 2009, 11:10:54 pm »
Sorry to steal the thread for a moment but was just wondering if a duramax swap has ever been attempted in these trucks?
Offline werewolfx13
« Reply #8 on: March 03, 2009, 12:03:48 am »
IIRC, it wont fit between the framerails.
Chris
'83 Chevy c10 Silverado SWB
