Author Topic: used 350 HELP PLEASE  (Read 30310 times)
Re: used 350 HELP PLEASE
« Reply #30 on: March 11, 2009, 09:04:37 am »
I seen several v6 to v8 swaps done. None had a special frame, so like ccz145a said, we need pics. The v6 is just a v8 with the fromt 2 cylinders cut off. It will be longer, so I dont understand you measurements as being a problem. You should just be able to bolt the mounts to the frame, the clamshell mounts to the engine, and drop it in. Give us some pics so we can see what you see.
Offline murraygmc
  • 85 gmc 4x4
« Reply #31 on: March 11, 2009, 09:55:09 am »
ok ill try but me and the old lady  split and it was her camra and the only thing i got was my truck and tools  so my truck is an hour away siting at dads but  ill get picks this weekend  and have them posted by sunday night  thanks any  but let me get this sraght........ ill just put  the motor block mount.... put it on the block take the other part of the mount and bolt it to the frame mount and thats it no moving or cutin ????  thanks
85 gmc high serria 4x4
« Reply #32 on: March 11, 2009, 09:14:29 pm »
You shouldnt have to cut anything. The guys I have seen do this couldnt fabricate a flat plate. We just need some ics, who knows, you may have something way out of the norm. You should just be able to bolt the rubber mount to the frame and the clamshell to the engine and drop it in.
« Reply #33 on: March 11, 2009, 11:04:37 pm »
I don't know why you are having a hard time with this. Definitely add pix when you can. I took some pix of my mounts today for you but haven't had a chance to put them up yet since I just got in from working on my 74 all night (again). I'll try to post pix tomorrow
« Reply #34 on: March 12, 2009, 12:44:47 pm »
Offline murraygmc
  • 85 gmc 4x4
« Reply #35 on: March 13, 2009, 07:06:52 am »
arighty vill the motor mounts aint an issue its the frame bracket thay bolt to but yesterday i wnt to a junk yard and got some frame mounts off a truck that had the 350 it was a 87 4x4 so im hoping thay will mount right up  if not im welding the motor in  lol        if i have any probs ill post picks by sunday night  thanks  i tell every one about a v6  to v8 swap and i just get this deer in the head lights look  thanks agan
« Reply #36 on: March 13, 2009, 10:18:55 pm »
I don't know why  ??? I've done plenty of V8 conversions and never had to change anything other than the motor mount position.
Offline murraygmc
  • 85 gmc 4x4
« Reply #37 on: March 16, 2009, 09:05:07 am »
ok boys iv got the swap done i had to take the frame mounts out of a 87 chevy and take my crossmembers lil brackets off and out of the way     the 87 frame mounts  bolted right up to the crossmember and had the 350 siting in thare bout a hour later  i had quit for the night then had it runing sat morning thanks 4 all the help really thanks
Offline oldwhity
« Reply #38 on: March 16, 2009, 09:36:17 am »
Woohoo! Fun wasn't it? Congrats. :)
Rob G.
81 Chevy K20 4x4 LWB stepside
« Reply #39 on: March 16, 2009, 10:13:57 am »
Did you take pix of the differences?
Offline murraygmc
  • 85 gmc 4x4
« Reply #40 on: March 16, 2009, 11:18:38 am »
no man srry like i said yhe ol lady took her cam and i dident have enugh light to make my phone work right  srry
« Reply #41 on: March 16, 2009, 01:36:18 pm »
I haven't ever had swap issue either other than just moving the mount around.  I would really like to see comparison pics, but...
« Reply #42 on: March 16, 2009, 10:21:05 pm »
I'll post pics on my V-6 to V-8 swap on my 2 wheel drive if you are interested.
« Reply #43 on: March 17, 2009, 12:20:37 am »
Did you have the same issues?  I think your pics are already here...
Offline murraygmc
  • 85 gmc 4x4
« Reply #44 on: March 17, 2009, 07:14:44 am »
he shuldent have  ran into the same probs 2x4 an 4x4  are way difrent but i could defently c where he would have trouble like i said i bought new  motor mounts and robd the frame mounts off another truck .   the cross members are riveted in but all you need to do is take off the suport bracket (just unbolt)   and the frame mount bolts right in to the cross member its so easey but i could have pulld my hair out till i had it figured out   ;D ;D ;D
