Author Topic: converting to newer style interior  (Read 6398 times)
Offline 73c10Shorty
  • 73 Chevy Shortbed
« on: March 09, 2009, 09:25:16 am »
I would like to upgrade to the later style interior. I'm not sure when it starts but I like the 86 interior. Would this newer interior bolt right into my 73 or is modification required? Thanks for the help!
1973 C10 Shortbed, 350/350
Offline HAULIN IT
Re: converting to newer style interior
« Reply #1 on: March 09, 2009, 09:51:58 am »
Yes & No, would be the correct answer. The door trim panels are longer on the '77-up. So if your replacing doors...buy the newer ones, if not, you will need to drill a few holes at the bottom & use spacers between the door & trim panel & use long screws. You will also need the '77-up "long" window regulators.
 The dash pad is similar, it works, but needs a little help. The gauge cluster bezel  will not have the wiper switch hole, depending on which one you get (non A/C), you may be able to cut the hole or use a '81-'82 bezel, it matches the dash pad & has the switch on the dash.
 The seat, ect. goes in fine. Lorne
Offline 73c10Shorty
  • 73 Chevy Shortbed
« Reply #2 on: March 09, 2009, 12:39:28 pm »
Great thanks, that clears it up for me. Too bad I didn't ask this question before I bought an 86 dash bezel! Oh well... it didn't set me back much. As for the dash pad, what kind of help does it need?
Offline HAULIN IT
« Reply #3 on: March 09, 2009, 01:00:27 pm »
As I mentioned, if you have a non A/C '86 bezel, you can use it...just figure where the rectangle hole needs to be, based off of your old one bezel. Drill a couple holes & file the corners square. If you got an A/C bezel, the vent is where you need the switch I believe.
 As for the dash pad, I'm thinking some of the slots up along the dashboard aren't in the same place, it's been a long while since I did this, so I may be off a little. Lorne
« Reply #4 on: March 09, 2009, 05:30:33 pm »
The Dash pad should swap out fine if you use all the year specific parts.
