Author Topic: How did you run your exhaust with a fuel cell  (Read 4384 times)
Offline 82gmc3/4ton
« on: March 10, 2009, 04:45:47 am »
I wanted to know how you ran your exhaust if you have a fuel cell between the rails of your frame?Especially if you have a plastic fuel cell. Thanks
Offline 69byrd
  • Haulin!
Re: How did you run your exhaust with a fuel cell
« Reply #1 on: March 10, 2009, 07:02:23 am »
Turn downs in front of the axel.
Offline fitz
« Reply #2 on: March 10, 2009, 09:27:24 pm »
My exhaust runs on the outside of the frame and dumps in front of the tires. I can get better pics if you want.
Offline HAULIN IT
« Reply #3 on: March 10, 2009, 10:23:23 pm »
Here's mine:
 However, I wouldn't be afraid to run pipes beside it (over the axle & out following directly under the frame. The heat that far back isn't going to be that hot to cause any problems. One thing you could do if your still concerned is make heat shield(s) beside the tank. I made a "skid plate" for the bottom of mine (required by NHRA/IHRA), theres no reason you couldn't do something similar, just going up the sides higher & either mount it to the straps or to the bottom of the frame. Lorne
