Members Rides
1975 Blazer!!!!
14
15
16
17
18
Topic: 1975 Blazer!!!! (Read 488461 times)
mercado1211
Re: 1975 Blazer!!!!
Reply #210 on:
April 22, 2022, 09:11:39 pm »
Hey Vile,
I was about to take the intake off after draining coolant to change the lifters and I thought I’d run it without valve covers. The valve covers had heavy wear marks from contact with the rockers. The knock disappeared. Lesson learned after a tear down and rebuild, always look for the simplest explanation for things.
1984 k10 LWB
1984 k5
1979 C10 SWB
mercado1211
Re: 1975 Blazer!!!!
Reply #211 on:
April 22, 2022, 09:11:56 pm »
1984 k10 LWB
1984 k5
1979 C10 SWB
mercado1211
Re: 1975 Blazer!!!!
Reply #212 on:
April 22, 2022, 09:25:53 pm »
The tear down was actually a good thing though, It had a Cam that wasn’t jiving with the set up. I couldn’t identify anything about the cam the original builder put in. He quit answering his phone. Two (5,7) cylinders were shadowing and the machine shop said it was a timing degree issue. The unknown cam had -3 etched on it so I might guess it had some custom grind.
1984 k10 LWB
1984 k5
1979 C10 SWB
Re: 1975 Blazer!!!!
Reply #213 on:
April 23, 2022, 06:55:41 am »
Well I'm happy to hear you found the problem! Are they stock rockers or roller rockers? Some tall valve covers should remedy that pretty easily for you.
mercado1211
Re: 1975 Blazer!!!!
Reply #214 on:
April 23, 2022, 07:54:30 am »
Thanks, I’m happy that ordeal is over as well. They’re stock stamped rockers. I have the tall covers but they hit on the sides of the rocker, the pushrod side. It has aluminum aftermarket heads with a configuration both style center bolt and older valve covers. I’m going to try grinding some clearance with a. Die grinder today and see if it helps.
1984 k10 LWB
1984 k5
1979 C10 SWB
Re: 1975 Blazer!!!!
Reply #215 on:
April 23, 2022, 08:12:53 am »
Good luck!
mercado1211
Re: 1975 Blazer!!!!
Reply #216 on:
April 23, 2022, 08:29:21 am »
Thanks!
1984 k10 LWB
1984 k5
1979 C10 SWB
Shifty
I bleed Bowtie red...
Re: 1975 Blazer!!!!
Reply #217 on:
April 23, 2022, 10:09:10 am »
Would either the thicker Fel-Pro valve cover gaskets (VS12869AC- 7/32" thick vs the OE 5/32", the Permadry version, or even the performance 1604's that are 5/16" give you the clearance without grinding?)
98 C2500 ext cab longbed
mercado1211
Re: 1975 Blazer!!!!
Reply #218 on:
April 23, 2022, 10:18:08 am »
I think I’m going to go and pick up some steel valve covers. The aluminum ones might still not give enough clearance if I grind them.
The issue I was having was the rockers were rubbing on the sides of the valve covers (pushrod side)pretty hard. I grinder one and decided not to even mess with the other one. I think these proform covers aren’t meant for steel stamped rockers.
1984 k10 LWB
1984 k5
1979 C10 SWB
mercado1211
Re: 1975 Blazer!!!!
Reply #219 on:
April 23, 2022, 07:51:21 pm »
Hey Shifty,
I used some stock vortec style valve covers and it fixed. Runs nice and smooth no rockers bashing and knocking. Motors dirty cause I was running it with no valve covers and put a cardboard dam on after the fact.
Thanks for the input
1984 k10 LWB
1984 k5
1979 C10 SWB
mercado1211
Re: 1975 Blazer!!!!
Reply #220 on:
April 23, 2022, 07:53:50 pm »
Sorry about hijacking your post Vile. I’ll go back to my mine now.
1984 k10 LWB
1984 k5
1979 C10 SWB
Re: 1975 Blazer!!!!
Reply #221 on:
April 25, 2022, 06:58:14 pm »
No worries. Got the carpet in, just need to set it outside in the sun for a bit.
mercado1211
Re: 1975 Blazer!!!!
Reply #222 on:
April 25, 2022, 07:30:35 pm »
That’s the next project for my sons K5. Looking good.
1984 k10 LWB
1984 k5
1979 C10 SWB
JohnnyPopper
Old Goof
Re: 1975 Blazer!!!!
Reply #223 on:
April 26, 2022, 03:54:49 pm »
Sweet! Stock color?
1973 C-20, 3+3 454 4BBL TH400 Water Injection
1980 C-10 under construction
Re: 1975 Blazer!!!!
Reply #224 on:
April 26, 2022, 06:04:15 pm »
Yes, keeping all the factory colors. Saddle
14
15
16
17
18
Members Rides
1975 Blazer!!!!
