Author Topic: power lock/ window help  (Read 17210 times)
Offline eric.w.13
« on: March 15, 2009, 10:06:27 pm »
i have a 79 with the doors and power window harness out of an 82.  i have the complete power window harness for the doors.  my question is could someone show me where to attach the 3 wires for the harness in the fuse block.  i think i for where 2 wires go (above the bottom flasher) but i cant find the wire to connect the black wire to.  any help or photos would be great. thanks
current projects:  79 K10 truck,  heavily modified 77 Jeep CJ5 tube with an all chevy drivetrain.
daily driver 2003 chevy 2500HD 4x4  d-max
Re: power lock/ window help
« Reply #1 on: March 16, 2009, 02:26:35 pm »
One goes to the ground terminal on the side of the truck behind the dash, the power goes to the fusebox, the rest go in the doors...
Offline eric.w.13
« Reply #2 on: March 16, 2009, 03:20:30 pm »
ok.. so basically i just need to ut the end off the clack wire and connect a ring terminal and attach it to the ground behind the dash.  everything else i have hooked in.  on the power wires-  they will only fit in 1 spot on the fuse block right?   i only found 1 spot that the orange wire fits and 1 slot where the red wire goes in.  does this sound right?
« Reply #3 on: March 16, 2009, 03:37:54 pm »
That was hard to read....
The black wire should have a spade terminal and it will slip over one of the slots on the drivers side under the dash.
Offline eric.w.13
« Reply #4 on: March 16, 2009, 10:48:40 pm »
sorry about the typos.  i had just got a call that my grandmother had a stroke so i was hurrying to leave.  it will be a few days before i get a chance to look.  i will be at the hospital in and out until she get better (if she even does get better)  she is 82 and we all know that it wont be long until she goes to be with the lord but i am not ready to say bye just yet.  :'(
« Reply #5 on: March 17, 2009, 12:18:20 am »
I pray that she has a full recovery.
Offline eric.w.13
« Reply #6 on: March 17, 2009, 06:52:48 am »
thank you very much.  i will keep you informed
i see you are in birmingham.  how crazy is it that i live in anniston?  i have a sister that lives in birmingham though.  you are just right down the road...  do you ever go up to grayrock?
« Reply #7 on: March 17, 2009, 10:49:51 am »
I know where  GrayRock is, but I haven't been there.  Toolmaster is one of the admins on the caos4x4 board and I still poke around there.  He still has his Zuk though, but I am trying to convert him to 73-87 Chevy's :D
